Can't Open TVPaint Topic is solved
Can't Open TVPaint
Hello:
I can not open TV Paint.
I had to replace my C drive. I also upgraded from Windows 7 to Windows 10.
So now I am using windows 10.
I had a zipped version of TVPaint Animation Pro 8.5. You had sent it to me a few years ago.
It is version TVP Animation 8.6.4.1173fPRO(32).exe
I unzipped it and installed TV Paint on the hard drive.
The program opened and there was a message about plugging in my dongle. (See attached screenshot)
I still have my dongle. I unplugged it and plugged it in several times, but TV Paint would not open so I could not draw with it.
I still have my registration codes if you need them.
How do I get TVPaint to open? If it matters, I plan to upgrade to TVP 11 Pro, but it will not be until next summer or fall.
Thanks
Chris
Thanks
Chris
Re: Can't Open TVPaint
For the dongle-problem, I would try to install the newest drivers from manufactors homepage. The dongle is called "Sentinel".
But I think you will not get your old TVPaint working on Win10 in general. Here is a discussion about the problem:
http://forum.tvpaint.com/viewtopic.php?f=10&t=10127
Maybe you should stay with Win7.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
You might be able to get it to run on Windows 10 if you create a new user account and install TVPaint on that account . You'll have to log in to that account to use TVPaint.
See:
http://forum.tvpaint.com/viewtopic.php? ... =30#p99723
See:
Thanks Animark and D.T. Nethery.
Before I try your solutions, does anyone on the TVPaint staff have any advice?
Thanks
Gochris
Thanks
Gochris
I would have tested those first (latest safenet ultrapro dongle drivers to reinstall and clean windows 10 session)
If it doesn't work, we will do a teamviewer session with you.
Sorry to be a problem... but I am a little confused.
I am trying to download the latest safenet ultrapro dongle drivers.
I go to Safenet's website
https://sentinelcustomer.gemalto.com/sentineldownloads/
I search for Sentinel Ultrapro.
I get a list of downloads. (See screenshot)
There are several downloadable files listed.
But how do I know which file to download and install?
http://www.tvpaint.com/owncloud/index.p ... KniTfO4Vul
Click on the link above.
However, please keep in mind you are using a +10 years old version and we cannot guarantee such an old software will work with current OS / drivers.
Yes I understand that.
I thank you for your patience with me!
Elodie:
Thanks for the help with the download link.
I downloaded the sentinel driver and installed it.
I click on the TVPaint shortcut.
Now the TVPaint registration window comes up. So that's good!
A window comes up. It says "Your License Key was not found."
At the bottom of the page, I input my User Name, Organization and my UNLOCK CODE
I click on the "register" button, and
"UNLOCK CODE Required!" appears on my screen.
So I sent all of the proper information to the TVPregister@tvpaint.fr address
I can provide my Lock Code and Unlock code if you want it. I assume this has to be done privately, not on this public forum.
I am waiting for your response. Thanks!
Gochris
This information may help:
On the TVPaint registration window, I see two buttons at the bottom: one is "Register." The other is "Later."
If I click on "Later" I can use TVPaint. I can save files, and export Quicktimes.
Gochris
I have sent you your codes, just in case. If there is further issue with your codes, please answer that email (we won't chat about this on the forum )
Thanks for sending me the email.
I responded to your email.
I did not get it :s
(it's elodie [@] tvpaint . fr)
I just sent the email to the correct address.
Elodie:
I received the email.
I opened TVPaint as "Administrator."
Now TVPaint is working perfectly.
Thanks to everyone's help! Elodie, Animark, David Nethery... you're the best!
TVPaint community rocks!
This case is closed.
- thank you tvpaint.jpg (44.28 KiB) Viewed 41070 times
Haha, you're welcome, I'm glad that it worked
