This question comes from this tutorial ( the version used in the tutorial is tvpaint 11.0.1 ):https://www.youtube.com/watch?v=F9YPERoRcps
In tvpaint 11.0.8, even if I assigned the same color label to the animation layer and the sound clip, I still couldn't move the animation layer and let the sound clip follow.
I operate according to the video ( set the same color for them ).Is there anything wrong with what I did ? Can anyone help me ?
How to move the layer and sound at the same time? Topic is solved
Re: How to move the layer and sound at thes ame time?
I just tried it and it works for me . Did you make sure to hold down the CTRL key when you move the animation layer ? You must hold CTRL to make the sound layer move with the animation layer. You'll see the animation layer move first , then when you release it you'll see the sound layer shift to the same position as the animation layer.From Milk wrote: ↑21 Jul 2018, 07:28 This question comes from this tutorial ( the version used in the tutorial is tvpaint 11.0.1 ):https://www.youtube.com/watch?v=F9YPERoRcps
This is very useful! Thank you!D.T. Nethery wrote: ↑21 Jul 2018, 14:34I just tried it and it works for me . Did you make sure to hold down the CTRL key when you move the animation layer ? You must hold CTRL to make the sound layer move with the animation layer. You'll see the animation layer move first , then when you release it you'll see the sound layer shift to the same position as the animation layer.From Milk wrote: ↑21 Jul 2018, 07:28 This question comes from this tutorial ( the version used in the tutorial is tvpaint 11.0.1 ):https://www.youtube.com/watch?v=F9YPERoRcps
