Only changing certain part of canvas on 'Modify Project' Topic is solved
durianice
Post by durianice »
Hi, I wanted to make the top part of my canvas to be taller in 'Modify Project' but when I expanded the canvas, it made both the bottom and the top longer. Is there any way I could fix the bottom to not change and only allow for the top portion to get longer?
Padruig
Re: Only changing certain part of canvas on 'Modify Project'
Post by Padruig »
You can’t do this with modify project but you can get the desired result with the cropping tool. If you drag the crop box beyond the border of you canvas and apply it will expand the canvas.
As a side note, using the cropping tool will create a copy of the existing project with the changes you make. So you can go back to the original document if you want. Make sure you save the new “cropped” version you create.
durianice
Post by durianice »
Oh okay thank you so much! I just did that in my project and it's how I wanted it to look.
