TVPaint cannot import any file other than .tvpp Topic is solved
humble.bumble
Post by humble.bumble »
I'm using Windows 11 and TVP 11.7.2-64 bits.
Whenever I try to import a file, either by drag and drop or by going to file-import, one of these pop-ups shows. I've tried this with .png, .mov, .mp4, .jpg files. I've never had this problem before (I'm using slightly older TVPaint on my other PC, never had any troubles).
I have Quicktime installed. TVPaint has no problem opening .tvpp files. Anything else it doesn't open.
I've reinstalled everything and the problem doesn't go away. Please help!
Re: TVPaint cannot import any file other than .tvpp
Could you move the files to a place where there are no special characters in the path? Then try again.
humble.bumble
oh my god. YES. Thank you!! I am literally so stupid - can you believe I spent the whole day trying to solve this issue? The older version of TVP never had a problem with special characters, so it didn't even cross my mind.
Since I work in a mixed environment and get files from any origin I made it a habit long ago to sanitze file names as well as path names down to 7bit ASCII, even name layers that way. It pays in the long run.
