Super weird, my project is set to 24fps but when I export a movie from TVP, it goes super fast and the video is half the length, though the audio is the correct speed. Obviously pic to audio goes out of sync quickly. I need to set the export to 12fps to get the correct speed, but then my camera moves are stuttery.
Any tips here please? I've tried with 1:1 settings, with half size, with MP4 and MOVs.
TVPaint Pro 11.7.5 Mac 64-bit, Mac Mini M4, 24gb ram, macOS Sequoia 15.5, Wacom Cintiq 22" HD driver 6.4.9-2, Apple Magic keyboard, wired logitech mouse, Crucial X9Pro ext SD drive which has my work, Western Digital ext drive for time machine backups, also backs up work folder on Crucial drive.
Dean wrote: ↑24 May 2024, 09:15
Hello, which video player do you use?
Could you send me a link to this exported project via PM, please?
Thanks Dean. I've tested on Quicktime, VLC and Infuse, all with the same results.
Will DM you the normal (fast) export as well as the 12fps export, thanks
Thank you to Dean who very kindly had a look at my project file and identified the issue - it was the Camera Parameters which were set to 12fps. Changing that to 24fps solved the problem. Shew, dunno if I would have found that myself.
Hm, interesting. I wonder how much sense it makes, anyway, to allow camera FPS to override project FPS?
