How to set a specific starting frame number? Topic is solved
BruceM
Post by BruceM »
I've scanned and imported the drawings for a scene. Can someone tell me how I can change the frame numbers in the timeline so that the starting frame number corresponds to the starting frame number of the scene on my exposure sheet? Rather than starting at frame "0" or frame "1"?
-Bruce
Re: How to set a specific starting frame number?
At the bottom left, in the timeline, you have different option (background, group, start, sound, etc.). Click on Start to choose the start frame (0, 1 or custom).
BruceM
Post by BruceM »
Wow! That works perfectly.
Thanks again Elodie!
BruceM wrote:I've scanned and imported the drawings for a scene. Can someone tell me how I can change the frame numbers in the timeline so that the starting frame number corresponds to the starting frame number of the scene on my exposure sheet? Rather than starting at frame "0" or frame "1"?
-Bruce
If you want your scene to start at a specific frame number set the Mark In to that frame number .
Say you want the the scene to start at frame 25 , it would look like this:
(click image to see it larger)
Audiovisualisa
Post by Audiovisualisa »
I have got an additional question to that:
Does the start frame number option at the bottom left of the timeline also exist in older TVPaint versions?
At university we use TVPaint 10.0.6, I searched for this function but could not find it anywhere yet...
Audiovisualisa wrote:I have got an additional question to that:
I believe that is new in TVPaint 11.
However, for TVPaint 10 there is a custom panel that Hervé Adam made called StartFrame 0 or 1 , which you can use as is or you can copy and paste those buttons (0 and 1) to your Animator Panel , under Misc. Tools.
viewtopic.php?f=10&t=4162&p=34431#p34421" onclick="window.open(this.href);return false;
By the way, you should lean on your university tech support admin to UPDATE from TVPaint 10.0.6 to the most recent iteration of TVPaint 10 , 10.5.7 .
Audiovisualisa
Ok, thanks for the info! :)
