Completely reset TVPaint? Topic is solved
schwarzgrau
Post by schwarzgrau »
Is there a way I can completely reset TVPaint to all it's default setting, so I can start from scratch?
Re: Completely reset TVPaint?
Open the Start-Up Panel (Preferences panel > Startup tab, and choose "Open Startup Panel" in the first pop-up), then restart the software.
You will then have the choice to create or delete a configuration.
Delete the one you are currently using to return to a default one (if you are using the one named "default", it will still be erased and be recreated anew).
schwarzgrau
Oh thank you
