flip project horizontaly
Is there a way to flip all the layers horizontaly at the same time without merging? As many animators I like to check my animation constantly by flipping (mirror).
I checked the modifyproject-panel and saw that there was a possibility to rotate the project, but not to flip it.
I can think of work arounds with the keyframer, but to check for errors now I mirror all the layers which is quite time consuming.
- malcooning
if I understand you well, you want to have a quick mirrored preview of your animation, with all its visible layers, so that by previewing your animation this way you can get a more 'objective', or 'external' view of it?
Try the attached custom button. it duplicates the project, merges display, and zooms out (so you won't have to step away from the desk). It's not a perfect solution, as it still will take time to merge the layers in case you have many of them, but I tried it with line tests at 1600x900 pixels and was a breeze.
NOTE: importantly, you must update TVPaint to the latest release (released today) 8.5.4, as it fixes a bug that existed in the 'duplicate project' command.
- Flip horizontally.zip
- (2.07 KiB) Downloaded 1448 times
i think its a nice feature idea...
to be able to mirror the project as a whole in the modify project panel.
now you can rotate the project as a whole
but there is no way to mirror it (on the x and y axis) with one click, while keeping all its layers
To Zigotto:
I mean flipping spatially on the x axe
I work quite realistic, and "mirroring" the drawings helps me to find errors that I don't see anymore after working on a drawing for a while.
To Malcooning:
Thanks for your solution, but since I want to clean the animation in flipped view, I want to keep my layers without merging them.
To Tantalus:
Since you agreed with me I'll make you some coffee, and bring it to you all the three meters that seperate our desks.
To Malcooning:
To Tantalus:
if it's only for preview, I think we don't really need to compute the project's frames, but just the preview rendering,Tantalus wrote:i think its a nice feature idea...
an extra option could be added in the Preview Setting panel, and we have already the place for it in the UI ...(see pict.)
well, in that case, to work on it in flipped position, yes, a "flip project" command would be the only way ...hisko wrote:... but since I want to clean the animation in flipped view, I want to keep my layers without merging them.
(a script could do the job actually, but a built-in command would be better/faster.)
- flipXpreview.png (3.92 KiB) Viewed 34355 times
- malcooning
- malcooning
no, he is not.Denny wrote:Uh, isn't he asking for something as simple as Image > Modify > Flip horisontally?
I've made my own shortcut for it (ctrl+r - used in another program as well) and then connected to my wacom. It's a blast.
If he uses this function he'll need to flip any layer individually. He wants a flipped PREVIEW, of the whatever is displayed, and the ability to draw on top of that. but without the permanence of flipping everything for good.
Re: flip project horizontaly
Is there any updates in regards to this subject?
It is a very big wish for me as well. At the moment I export out my scene and flip the preview in PdPlayer, -BUT it would be very much appreciated to stay inside Tvpaint..
It has been implemented a long time ago. It is a fantastic feature that I use often.
Go to View- Flip Horizontally
That's it.
That's it.
If I'm not wrong (I'm on the bus without à TVPaint to check this), the shortcut is ] or [ to flip horizontally.
you ride on a bus without tvpaint!?
It does not work on BlackBerry phones
