Here’s an odd crash behavior I notice in 11.0.3 32bits version (I'm running it on Mac) -
If I duplicate a Color and Texture Layer , then assign the duplicate CTG layer to a new source layer (because some slight changes were made to the clean-up line layer and the fills need to be adjusted slightly to fill the outlines of the corrected clean-up layer ) it immediately CRASHES TVPaint 11.0.3 32bits .
Note that the same crash does not occur if I do the same thing in TVPaint 11.0.3 64bits version . But I frequently use the 32bits version because my editor requires movie files exported in Apple Pro Res 4444 and that is not available to me in the 64bits version.
Crash in 32bits version when duplicating CTG Layer
Re: Crash in 32bits version when duplicating CTG Layer
Hi,
Sorry, but I cannot reproduce the crash. If I duplicate a CTG layer and then assign a new source layer or a second one, it works fine.
Can you still reproduce it ?
Is it linked to a specific project ?
Mac Developer
Is the bug still there in version 11.0.6 ?D.T. Nethery wrote: ↑03 Feb 2017, 21:09 Here’s an odd crash behavior I notice in 11.0.3 32bits version (I'm running it on Mac) -
I have not been able to duplicate the problem in 11.0.6 32bits version . (so hopefully it is now fixed ...)Elodie wrote: ↑16 May 2017, 08:05Is the bug still there in version 11.0.6 ?D.T. Nethery wrote: ↑03 Feb 2017, 21:09 Here’s an odd crash behavior I notice in 11.0.3 32bits version (I'm running it on Mac) -
