PPalette 7.50 (Mac/PC)
Re: PPalette 7.50 (Mac/PC)
never mind I worked it out
Just needed to add "script=Startup.grg" to the shortcut used to launch TVPaint and all is well...
Ah, fantastic! Sorry I missed your last response.Gravin wrote:never mind I worked it out
(Win7x64, TVP Pro 11 32-bit)
Is there Windows 7 64-Bit Version for TVPaint 64-Bit? It doesn't seem to work. I installed it at "F:\Program Files\TVPaint Developpement\TVPaint Animation 10 Pro (64bits)\plugins', Restarted TVPaint, and Look at 'Windows -> Plugin ->' . The PPalette isn't there.
- Animationriver
Hello!
Good day! )))
Mas os Sierra 10.12.5
How i do install Perceptual Palette?
Put files from this forum in a folder
Mac/applications/TVPAaint Animations 11 Pro.app/Contents/Resources/plugins
But (Windows-plugins) there is no this tool Perceptual Palette.
Please help!
Thanks.
Good day! )))
Please help!
Thanks.
- Animationriver
Mac os Sierra 10.12.5
Mark's Plug-in works only on Windows.
thank you!
Does PPalette ever work for Mac ?
A history from this thread:
Start edit by eric:
DOWNLOAD (Mac Universal)-->PPalette.bundle.zip
Sorry no .tvpx, because there are access rights problems if you are not the administrator of the computer...
To install it:
- unzip to get PPalette.bundle
- right click on you TVPA application (not on the icon in the dock, but the App usually in /Applications)
- select "Show Package Contents", this opens a finder window.
- navigate to "Contents > Resources > plugins"
- copy PPalette.bundle there (there sould already be some .bundle files there)
- enjoy !
End edit.
Then sometime later in this thread someone else asked how to install PPalette on Mac and they received this answer :
Because Fabrice and Elodie are no longer here, my question is addressed to Eric Matecki:
In the first post of this topic, you added a Mac version of PPalette. The files are still there to download . A friend of mine wrote to me: "I downloaded the PPalette.bundle and copied it to Contents > Resources > plugins as in the directions , but it does not appear in TVPaint 11.0.8 under Windows > Plug Ins." I also tried it and I don't see PPalette listed under my plug ins after copying the PPalette.bundle, so I am assuming the Mac version you compiled way back in 2011 was for TVPaint 9.5 or TVPaint 10 (what version were we up to in 2011 ? ) but it no longer works on TVPaint 11.
QUESTION: Will you ever be able re-compile PPalette for Mac to work with TVPaint 11 ? I hope so. But if not , or until that can be done , it seems to me that the first post in this thread should be edited again to remove the non-functional Mac PPalette bundle and make a note in big, bold letters: "PPalette plug-in is currently for WINDOWS ONLY" (and the title of the thread edited to read: PPalette 7.50 (Windows only) , instead of PPalette 7.50 (Mac/PC) . )
Then Fabrice wrote:
And Eric wrote:
Here is how it appears in the first post :
Start edit by eric:
To install it:
- enjoy !
End edit.
From a small experiment . This does work on 11.0.9 but only the 32 bit version. I tried 64, and it just wouldn't show up.
I don't really know if 64 bit is really necessary for any work I do, so I"ll just stick to 32 bit.
The new dongleless version of TVpaint doesn't seem like it offers support for 32-bit Tvpaint anymore.
Does anyone know how we could go about compiling this plugin for 64 bits? The source code appears to be available in the original post, I looked at it a bit, but I didn't understand what was there well enough to make any progress on it.
Is Lemec still around? Could he recompile it?
I use the pressure sensitive color picker all the time and really don't want to lose it.
TVpaint devs, could you help? Would me getting access to the TVPaint SDK let me compile it?
Thanks
Thanks
Hi, I'm still around. I was having difficulty compiling it for 64-bit a while back and gave up. I'm working right now but later tonight I'll try again to try and track down what it was that I was running into.
That would be awesome Lemec! Pressure sensitive color picker is a feature all art programs need!
Ok, I remember why I had problems with the 64-bit... The thing builds the DLL but it crashes when loading. I think I might need an updated 64-bit SDK.
OK, so apparently the SDK hasn't been updated in years. Ugh. I dunno what more to do. It's kind of out of my hands because I can't invoke any native functions in TVP without it crashing.
