No working disk drive on mac Topic is solved
Locked
inkcat
Post by inkcat »
Hello, I recently purchased TVP11, but just now figured out my Mac's disk drive doesn't work.
I've emailed the address given in the disc case itself (register@tvpaint.fr), with no response.
Can someone tell me how to install the TVP11 Standard software on my mac without the disc? Thanks a bunch!
o0Ampy0o
Re: No working disk drive on mac
Post by o0Ampy0o »
You will need a Lock Code and Unlock Code.
You can download the files from HERE
inkcat
Post by inkcat »
o0Ampy0o wrote: 10 Aug 2017, 01:20 You will need a Lock Code and Unlock Code.
I don't believe I have either. Where can I get them from?
o0Ampy0o
Post by o0Ampy0o »
I acquired my license through an approved private sale with the original owner so I have no experience purchasing the software directly from TVPaint.
I would imagine that you must receive these two codes whenever you purchase the software. The original owner had received them when he purchased the software.
When you acquired the disk could you have received the codes in accompanying paperwork?
With software in general, codes and serial numbers are typically supplied on the wrappers/boxes/printed User Guide/Manual and in email.
inkcat
Post by inkcat »
Just checked, there's absolutely nothing except the invoice number and dongle code.
o0Ampy0o
Post by o0Ampy0o »
Did you purchase this directly from TVPaint?
If so, I would contact them. I imagine they would normally have provided instructions once the required information had been presented.
inkcat
Post by inkcat »
That's why I'm here, I haven't gotten a response from the email provided, and it's been quite a while...
I've seen admins on here give the instructions I'm looking for through PM, so I figured this could work since the email method didn't.
o0Ampy0o
Post by o0Ampy0o »
What was the date when you purchased it?
Hello !
Please contact technical support here : http://www.tvpaint.com/contact-us and give your name, invoice and dongle #.
License activation and codes will not be discussed on the forums, so I lock the topic.
Locked
