Spritesheet Generator
Hello everyone,
Here is a script that I created that can generate a spritesheet of your animations.
spritesheet-generator.tvpx
(11 KiB) Downloaded 494 times
Here's a short example:
Click on the button in the panel:
The script will run and generate this spritesheet:
A png file containing the spritesheet will be saved in the folder in which your project is stored: my project is named "bluebird4", so the png file will be named "bluebird4_spritesheet"
Aaaand... that's it :)
As you've noticed, there are 5 images per line. If you have less than 20 frames in your animation, there will be 4 images per line.
If you'd prefer the script to generate only one line, then tell me and I will post another version of the script :)
NathanOtano
Re: Spritesheet Generator
Post by NathanOtano »
I have to download rpgmaker again now haha, thanks!
Animationriver
Post by Animationriver »
You genius!
THANKS!!!
ubik
Post by ubik »
Thanks for your work with my students to Unity!
tribute27
Post by tribute27 »
Thank you!!!!
Animationriver
version -2
Aha))
mox
Post by mox »
Cool!
I wonder if a script would work the other way around, from a spritesheet to a (animated) project ? :?:
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
It would be a lot more complex (and require a bit of user interaction), but I think it should be doable.
(yay, now I have a side-project :D)
I wonder if something could be done with the help of the grid. Import image, adjust grid so it separates all items, then cut along grid lines?
mox
Post by mox »
Nothing relevant, but after running the script, I got a new and perfect (generated) project featuring the spritesheet, while the automatic saved picture is empty but at the right size.
Jerome Lorin
Moxica (playground)
