Can I render what the lighttable displays ?
TVPaint
Post by TVPaint »
Certainly Peter.
And probably by having an effect that is a rendering of the lighttable because this is my understanding that the result obtained by Volker is absolutely normal finally, using a stack of ImageSource FX like that.
Edit : My bad, if you select the layer as the source in the SourceImage FX, that this layer is disabled and that yu apply in an empty layer, it seems to give the good result.
Volker
Post by Volker »
you are right, of course - stupid me :oops:
meslin
Re: Can I render what the lighttable displays ?
Post by meslin »
+1
I too would like a checkbox in the export dialog to render the current lighttable display (as Malcooning mocked up). It would be very powerful, in part because you already get such a nice realtime preview while you're tweaking the light table.
Maybe this thread should be moved to "feature requests."
Topic moved.
I have read the topic and honestly, I don't understand the point of exporting the light table display.
