Hi, I shut down my computer unexpectedly, and my file seems damaged and can’t open it.
(My friend have happened that about one month ago, and it happened on me yesterday...)
So I come here to look for some help, thanks !!!
The file: https://drive.google.com/open?id=1Q8Yds ... JU7R_l0gck
My OS version and software version:
win7 , 64bit
TvPaint Pro 9(9.5.3) , 64bit
My file is corrupted and need some help Topic is solved
Re: My file is corrupted and need some help
First of all, try to update your software, we did a lot of updates and bugfixes in version 9 after v9.5.3.
Go to the "Help" main menu, and then "Check for updates".
On holidays until May 5th
I've update my TVpaint, But the file still can't be opened.
Is there any way to recovery the damaged file?
what is your version number now that you have updated ?
it's 9.5.21
Hmm. This happened to a friend of yours about a month ago and you still don't backup your works-in-progress? Seems like the FIRST thing you should do is learn how to save multiple copies of your project, then do that every time you save...
I did save a backup, but it's three days ago. I still lost some of my progress.
I think I will save backup more often...
ok, so, send me your file with your lock-code , using a Private Message (PM) in the forum.
EDIT : file recovered, problem solved.
