Texturizer question Topic is solved
Texturizer question
After i worked my way through a layer with the texturizer (applying my texture frame after frame), when i finish and play back i see some frames that are a bit too far off.
how can i correct them without having to start over?
when i go into the texturizer panel i can only press "start" i then see the whole layer being re-rendered and i see the grid for each frame.
but when its done the grid is gone and i don't seem to have access to any control or option to adjust those grids...?
so : How to adjust a frame with texturizer?
Re: Texturizer question
So.... this is how to do it..
right click on the frame of the rendered texture.
on the bottom of the pull down you find modify texture.
this allows you to adjust the texture.
Ah great, thank you Peter!
Thank you, indeed for the concise explanation .
(I love when that happens: in writing out the question and posting it to the forum, something clicks and you find the answer !)
I just watched the tutorial about "Texturizer in CTG" But I can't find the "Select Color" button for Tracking Zone and Render Area.
Can anybody help PLZ.
Hello, you need to extend the Texturizer window from the right side to make the button appear, this is a visual bug which can occur on certain screen sizes with a scaling setting above 1.
Perhaps that information should be added to the User Guide ?
https://www.tvpaint.com/doc/tvp11/index ... -rendering
Good idea, I think we could also simply make the Texturizer's window default size bigger in the next update to avoid this issue.
+1. Yes, that would be a better idea.
