TOOLS X LAYERS - Assign a layer to a tool and switch both with one click.
Hi all,
This custom panel evolved out of a discussion happening over here: viewtopic.php?f=34&t=11097
The panel can be used to store your most commonly used tools for quick access. In addition to loading a tool, each button can also automatically chose a specific layer. This can be very useful for constantly switching between a sketch layer and a paint layer, or from a storyboard panel layer to a note layer to name a couple of examples. The tool and layer can be switched simultaneously with a single click or better yet - a keystroke or wacom button (if you assign shortcuts to the tool buttons).
Questions and feedback welcome!
Enjoy
David
Enjoy
David
- TOOLSXLAYERS.tvpx
- v1.1 released Jan 29 2018.
Recent Changes
-Better at reconnecting layers to tools between sessions, layer merges, etc.
-Less clutter in Embedded George Scripts, relies on stored scripts instead
-New Icons. - (852 KiB) Downloaded 387 times
David
TVPaint 11.7 Standard
System: 64GB RAM // 3 TB SSD // Core i7 8700K // NVIDIA GTX 1080// Windows 10 Home
Re: TOOLS X LAYERS - Assign a layer to a tool and switch both with one click.
Hi David,
Interesting experiment... I'm also very interested in your clever (help) file, too, using the tv_GetString command, a very innovative solution for online documentation. I'm going to try a few of my own experiments with it for some things I'm working on. Thanks for showing the way.
BTW, after I found that the \n line-wrap is available for insertion in various commands, I started adding multi-line Comments to some of my buttons - a very useful way to include roll-over instructions and info right inside the Button/Script tool!
Thanks Sven,
I really just needed a way for users to copy/paste some text - which you can't do with tv_warn. Of course having everything aligned to the left is a nice perk too
D
D
David
This is a great idea that is going to be very helpful. Thanks for sharing, David!
Thanks Sewie! Glad you like it.This is a great idea that is going to be very helpful. Thanks for sharing, David!
David
FYI everybody: I'll be updating it at some point so let me know what it needs.
You may notice that the target layer setting is not remembered from session to session. Fixing this is a priority for the next release but luckily it's super quick to re-assign the layer on the fly so it shouldn't slow anyone down much
David
I like the sound of this! So I can set new animation layers to always use a blue pencil, new clean up layers to always use black pencil, and new colour layers to always be a watercolour?
I'll have a good look at this before my next job.
http://www.daninski.com
Similar but, not quite. You set it up so that whenever you select the blue pencil, it chooses an animation layer. Furthemore, you have to tell it exactly which layer. Each tool can have a different layer connection for each clip.I like the sound of this! So I can set new animation layers to always use a blue pencil, new clean up layers to always use black pencil, and new colour layers to always be a watercolour?
What your suggesting is the inverse - to select the layer and automatically switch the tool. That's also a great idea but I think a lot harder to achieve with scripting. Not impossible but not what the script currently does.
Play around with it though. I think you'll find that for practical purposes it comes close to (i.e it will save you as much time as...) the way you're thinking of it.
David
TOOLS X LAYERS version 1.1 is up!
Download from the original post at the top!
Recent Changes:
-New Icons.
Recent Changes:
-New Icons.
David
That's a great, great tool ! Thank you for sharing !
- Animationriver
Cool! Great tool! Now Elodie can do cool iterations with this tool! Probably I can already expect a new small video on this topic!)) How to use this tool X layers? ))
Big Thaks for spyderheart!
Thanks Elodie!
There are a couple of George requests that could make it even better
http://forum.tvpaint.com/viewtopic.php?f=34&t=11097
http://forum.tvpaint.com/viewtopic.php?f=34&t=11204
Thank you! I've tried my best to to make the tool self-explanatory but you are absolutely right that a quick video always helps. It's on my to do list.Animationriver wrote: ↑30 Jan 2018, 13:12Cool! Great tool! Now Elodie can do cool iterations with this tool! Probably I can already expect a new small video on this topic!)) How to use this tool X layers? ))
David
Looking forward to trying this out. This seems like it will be very helpful. Thank you for sharing.
TVPaint 12.0.0 Pro
I made a quick video for the Japanese forum. I post it here too.
I recorded in a hurry so it is not "top-quality" but I hope it will be useful to apprehend the tool.
- Animationriver
Thank you for the video.
But...
