Wacom Erase setting to work for all tooltypes
The wacom erase setting on the penswitch works perfectly in tvpaint.
i'm refering to choosing the erase option on the wacompenswitch in the wacom driver software.
Within TVPaint this gives you a toggle for a different toolchoice and setting for each drawingmode type.
And it works for :
One point dot
Stroke.
Dot stroke
Line
However....
i would like it to also work for other functions like the freehand fill and the paintbucket.
Sewie
Re: Wacom Erase setting to work for all tooltypes
Post by Sewie »
Peter Wassink wrote: 15 Mar 2018, 12:50 ...
What is this option and where can it be found in the Wacom driver software...? Can you post a screenshot?
Sewie wrote: 16 Mar 2018, 10:15
I think he means setting the Wacom pen button to Right-Click , which activates Erase mode when pressed , but when released returns to the previous drawing mode. This works for stroke, line, dot stroke, one point dot , but he is requesting that the Right-Click to enable Erase mode would also work for freehand fill and paint bucket.
Screen Shot 2018-03-16 at 8.07.59 AM.jpg (70.93 KiB) Viewed 20477 times
Sewie
Post by Sewie »
So it's just the right click function for the pen button.
That's so far off from...
Peter Wassink wrote: 15 Mar 2018, 12:50 The wacom erase setting on the penswitch ....
..that I wouldn't even call it semantics.
I don't know ... perhaps I don't understand what Peter is referring to ?
Maybe it is this ? --
Sewie
Post by Sewie »
I think both your suggestions make sense, David. :) (And thanks, btw)
It was Peter's confusing post that I was commenting on.
Mmmmh...are you calling my post confusing?
I used two whole sentences to explain exactly what i meant and you still managed to misread... :P
i was indeed referring to what you see in Davids second screenshot.
"The wacom erase setting on the penswitch"
