Framed Ink Marcos Mateu-Mestre BRUSHES Topic is solved
Animationriver
Post by Animationriver »
There is such a book. And there are such pictures in it.
Could you tell me. How to create the same brush to draw the same calligraphic drawings?
I would be very grateful. If you share a pallet.
Surely a lot of people thought how to make such a brush.
Help.. :D
neonnoodle
Re: Framed Ink Marcos Mateu-Mestre BRUSHES
Post by neonnoodle »
Framed Ink is a wonderful book! I believe you could accomplish anything in that book with the Pen brush in TVPaint. The aspect is about 50% (so it looks like a calligraphic nib instead of a circle), and the angle looks like 45 degrees. Turn off anti-aliasing and bind size to pressure. That's it! The rest is skill.
Most of the drawings in the book are in black, white, and middle gray.
Animationriver
Can someone share the library?
i agree with Zoe.
these drawings are brushes so the regular tvpaint penbrush will get you close.
but you could create a custombrush if you want to built in some randomness, make it a bit less sterile.
for instance by having the circle shape of your brush be an animated custombrush and connect that animation to pressure or randomness
I have seen animation drawings done in TVPaint by Uli Meyer that look exactly like Ronald Searle ink line drawings . I asked Uli: "What custom brush settings do you use , Uli ? " Uli replied: "No custom brush settings, I just use the standard TVPaint 5.00 brush ."
Screen Shot 2018-04-24 at 8.41.26 PM.jpg (26.81 KiB) Viewed 35101 times
Animationriver
Animationriver
Animationriver
HELLO.
THIS IS MY solution.
Thanks. :D
Calligrapher My Brushes.tvpx.zip
(37.59 KiB) Downloaded 1473 times
Снимок экрана 2018-04-28 в 1.17.34.jpg (59.46 KiB) Viewed 35023 times
D.T. Nethery wrote: 25 Apr 2018, 01:07 I have seen animation drawings done in TVPaint by Uli Meyer that look exactly like Ronald Searle ink line drawings . I asked Uli: "What custom brush settings do you use , Uli ? " Uli replied: "No custom brush settings, I just use the standard TVPaint 5.00 brush ."
And to think Ronald Searle used montblanc golden fountain pens worth 800 Euro a piece... you get that line quality included for free with TVPaint!!! great selling point, team!
Animationriver
Not so simple. I needed to get a narrow start and a narrow end of lines with a blunt end and start.
If someone makes a better result. I will be grateful.
