Strokes will create straight line suddenly
swiftsketcher
Post by swiftsketcher »
Hi, I'm currently on TVP 11 version 11.0.8-64 bits, on Mac OS X Sierra 10.12.6, Wacom driver 6.3.29-6, on the Cintiq 22HD.
Drawing curves produces a sudden straight line in the drawing as shown below:
Screen Shot 2018-04-29 at 9.49.26 PM.png (42.81 KiB) Viewed 19629 times
Is there any way to fix this?
Re: Strokes will create straight line suddenly
i am now on linux:
i have the same isue.
fast drawing bug.png (69.16 KiB) Viewed 19604 times
it seems to be unrelated to brush size or complexity.
the effect is the same with a large custombrush as with the standard pentool
on this machine: no problems, even when circling very fast with a heavy brush. no straight lines show up.
gjeaks
Post by gjeaks »
I have a similar problem, but it happens only when I start drawing the curve - the beginning of the curve is almost always a line segment when drawn fast. :(
(on windows)
is there a solve?
MacBook Pro 2019 / macOS Sonoma 14.0 / Core i7 / 16 GB / Intel UHD Graphics 630 1536 MB / Cintiq Pro 16 / TVP PRO 12 64-bit
gjeaks, your issue could be because of the line smooth function.
try drawing those shapes with line smoothing switched off.
Lise
Post by Lise »
Try to reset your application (TVPaint or other softwares) in your Wacom Tablet Properties. It often solves all my problems with my Companion 2.
Here is a detailed explication for removing/adding an application : http://www.tech-recipes.com/rx/48031/ho ... plication/
gjeaks
Post by gjeaks »
@Peter
I have tried it without line smoothing. Doesn't seem to work :(
Jet
Post by Jet »
@gjeaks
Maybe take a look at this post: https://www.tvpaint.com/forum/viewtopic ... 60#p108060
OS: Win 11 / RAM: 128GB / GPU: RTX 3080 Ti / Display: Cintiq 27
