Key:Layer:Exposure:DeleteInstanceHead via George script Topic is solved
MaciejGliwa
Post by MaciejGliwa »
I am trying to write a script in George which would remove "keyframes". I can do that via the Key-Layer-Exposure-Delete Instance Head command in TVPaint. Is there any George command that would allow me to implement that functionality inside of the script?
Maciej
Re: Key:Layer:Exposure:DeleteInstanceHead via George script
Interesting puzzle. I'd like to see what other script solutions there might be... :)
Here's a script fragment that works almost like Key:Layer:Exposure:DeleteInstanceHead, except it won't work the same for the first image of the layer:
tv_LayerCurrentID
LayerID = result
tv_LayerGetImage
Frame = result
PrevFrame = Frame - 1
NextFrame = Frame + 1
tv_LayerImage PrevFrame
tv_ImagePush
tv_LayerImage Frame
tv_ImagePop
tv_LayerReComputeExposure LayerID Frame NextFrame // (updated a second time: to limit ReComputeExposure to current frame and next frame)
It copies the frame preceding the current frame, to the current frame, then uses tv_LayerReComputeExposure to turn the original frame into an exposure of the previous head frame.
sven
MaciejGliwa
Thank you so much for the reply and code. I will try it out. Really appreciate the help!
MaciejGliwa
Works great! Thanks again!
