I have the shuttle wheel on my Cintiq remote programmed to rotate the canvas. However, as it rotates up towards 90 degrees, it shrinks the project area so as to keep it all in screen.
Is there a way to rotate the canvas without this shrinking of the project area? So that throughout the rotation, it maintains the same size?
How to program rotation of canvas without shrinking the size? Topic is solved
Re: How to program rotation of canvas without shrinking the size?
Make sure Auto-Fit is disabled . (see screen shot)BruceM wrote: ↑25 Sep 2018, 20:58 I have the shuttle wheel on my Cintiq remote programmed to rotate the canvas. However, as it rotates up towards 90 degrees, it shrinks the project area so as to keep it all in screen.
Thanks D.T., but how do I disable Auto-Fit?
If Auto-Fit is enabled you can see that it is selected/ lit up ... I don't know exactly how to say it ... I mean , if you click on it , now you see it's enabled right ? Now click on it again, it is disabled.
Yes! Exactly right! That did it.
Thank you again!
Thank you again!
