Hello, I was wondering if there's a way to use the same image guideline across multiple clips, or a way to export/import/share the guideline image I'm using on the current clip so other users can load it.
EG. Used for coloring characters based on the image guide, keeping proportions, tracing, etc...
Image Guideline Across Multiple Clips
www.cocoalopez.com
vimeo / 156794487
Desktop: TVP Pro 11.0.8 - 64bit Win 7 x64 48GB RAM - GTX1070 - Cintiq 27QHD Driver 6.3.29
vimeo / 156794487
Re: Image Guideline Across Multiple Clips
You can't load your guidelines in other clips.
But if you wish to get the same image guideline in another clip, the image should be stored in the library. Images in the library are accessible through different clips.
You can then load your image in the guideline from the library.
Melanie • Animator
Hello Melanie thanks for replying, that's what we've been doing but we thought there was another way of sharing the same guidelines or references across clips/users so they would be automatically loaded.
Thanks again
Thanks again
www.cocoalopez.com
vimeo / 156794487
vimeo / 156794487
