Cotton paper structure
With the help of some friend I found the material in question is called "Baumwolle grundiert mittelgrob", so it's cotton prepared for painting. Some online search dug up this:
I prepared this and got this version:
Baumwolle2.tif
Baumwolle2.tif (209.62 KiB) Viewed 3011 times
Export as DEEP, put into paper folder, restart TVP, use as paper with hardness 100, size 200%, invert:
Animationriver
Re: Cotton paper structure
Post by Animationriver »
BIG THANKS!!!
BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!
BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!
BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!!BIG THANKS!!! :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :idea: :idea: :idea: :idea: :idea: :arrow: 8)
Animationriver
"Export as DEEP"
How?
Berne1956
Post by Berne1956 »
Also didn't get, how to make it. Could you explain it?
Berne1956
Post by Berne1956 »
Hmm, since I read about this piece of information, it's kinda stuck in my head. Could anybody explain it? :?
Oh please. Didn't you ever take a look into the dropdown file format list in export window? There it is: DEEP, right between CINEON and DPX. That's the format TVP uses for paper structures. It's in the manual.
Another trick for creating your own paper from the current cutbrush...
Create a new button/script, embed the following seven lines:
tv_ReqString "Enter name for new paper"
PaperName = result
IF PaperName == 0
  tv_warn "no name was entered... try again"
  EXIT
END
tv_PaperFromBrush PaperName
Clicking your new button: Whatever the contents of your cutbrush, a new paper will be generated and inserted in the paper list (using the name you enter).
sven
Krishna579
Post by Krishna579 »
Great Information!!!!
