Mac OS Catalina, Mojave and High Sierra (update 08/10/2019)
Re: Mac OS High Sierra (update 01/08/2018)
JeremyN wrote: 08 Nov 2018, 08:15 Hi,
Only 32bits version works for TVPaint 10 , but for TVPaint 11.0.8 there is no problem with the 64bits version on Mojave.
Ok, no problem with 64bits version of TVPaint 11 on Mojave , but what about 32bits version of TVPaint 11 on Mojave ?
JeremyN
Post by JeremyN »
D.T. Nethery wrote: 08 Nov 2018, 13:54 Ok, no problem with 64bits version of TVPaint 11 on Mojave , but what about 32bits version of TVPaint 11 on Mojave ?
It works too... but maybe are you talking about Standard version of TVPaint 11 which exists only in 32bits ?
We are currently working on a Standard version which will work on 64 bits but I can't say when it will be released.
Mac Developer
Bea
Re: Mac OS High Sierra & Mojave (update 01/08/2018)
Post by Bea »
I have been using Tvpaint for months on my Mac Book Pro with MacOS High Sierra Version 10.13.6 with the drivers that you sent me.
I don't know why it has stopped working.
The dongle is connected correctly (the yellow light is on), but when I start the software, a message window appears saying that the Tvpaint doesn't detect the dongle.
I have re-started the computer several times, and tried with another usb-c adaptor, but the same message appears.
Could it be the drivers?
What can I do to solve this?
Thank you!
Hello Bea,
I contacted you via email to solve this :) Will update this thread when we find the solution.
Wayne Carlisi
Post by Wayne Carlisi »
Does anyone know how to scroll through the timeline and not have to see each frame? Meaning the drawings and not the frames.
Also, what is the hotkey to create a new instance on a High Sierra Mac?
Thanks,
Wayne Carlisi
Wayne Carlisi wrote: 28 Mar 2019, 01:41 "Does anyone know how to scroll through the timeline and not have to see each frame? Meaning the drawings and not the frames."
Keyboard shortcut Right = Go to Next Instance , Keyboard shortcut Left = Go to Previous Instance
which is different from Keyboard shortcut . (period) = Go to Next Frame and Keyboard shortcut , (comma) = Go to Previous Frame.
[click on the images to view them larger]
https://www.tvpaint.com/doc/tvp11/index ... es-general
Any of these keyboard shortcuts/hotkeys can also be assigned to Wacom Express Keys or Touch strips/Touch wheels .
ALSO , in the project interface on the Playback toolbar , there are buttons for Previous Instance and Next Instance,
Previous Frame and Next Frame.
Thanks,
Wayne Carlisi
It would be the same hotkey used to create a new instance on any other version ... all keyboard shortcuts are listed under Preferences > Shortcuts
If you search the Shortcuts for Insert , you'll get a few options:
- Insert New Instance (same as the Handy Custom Panel command Insert New Instance) .
or
- Insert Instance Before Current Image
- Insert Instance After Current Image
Any of these shortcuts could be assigned to a hotkey. In the attached image I have Insert New Instance assigned to the W key (it can be any key you want)
The same command to Insert Instances is in the Handy Custom Panel:
https://www.tvpaint.com/doc/tvp11/index ... nced-handy
If you Right-Click on the Timeline , one of the options on the pop-up menu is Insert Images (although to be consistent this should actually say "Insert INSTANCES" )
Anyway, any of these methods will work to insert new blank instances on the Timeline .
Insert Images from Timeline Pop-Up_Menu.jpg (74.39 KiB) Viewed 55418 times
Wayne Carlisi
Thank you, buddy. Much appreciated David.
Wayne Carlisi
Does anybody know how to make all frames to 1's in a simple way, instead of having to do it manually? Thanks much. :)
Wayne Carlisi wrote: 15 Apr 2019, 22:12 Does anybody know how to make all frames to 1's in a simple way, instead of having to do it manually? Thanks much. :)
Select all the frames you want to convert to 1's .
Handy Panel - Set Exposure - 1
(same thing if you want to convert a series of frames to 2's : Handy Panel - Set Exposure - 2 )
Optionally, you can create a new action button with this command line:
Layer:Exposure:Break
to use:
select any exposure in the current layer, click the button and the exposure becomes an instance...
select any mult-frame group in the current layer, click the button and all selected frames become instances...
Wayne Carlisi
Thank you again David. Much appreciated!
Sloppytoons
Post by Sloppytoons »
Any news about Mojave and TVpaint? I have TVP 11pro, and the software won't recognize my dongle :( I've sent an e-mail yesterday, but no reply :( Maybe I'm impatient as it was 21 hours ago. I should wait 3 more hours.
My regular IG account: Sloppybunnytoons
Sloppytoons
OK I fixed it. If anyone else have troubles, just go to your settings, Security and privacy, then on the bottom there is a little sign saying Sentinel wants to do stuff, click "allow", reset computers, and TVPaint will work ;)
Sloppytoons wrote: 17 May 2019, 12:52 OK I fixed it. If anyone else have troubles, just go to your settings, Security and privacy, then on the bottom there is a little sign saying Sentinel wants to do stuff, click "allow", reset computers, and TVPaint will work ;)
Yes, that's the fix (covered in the first post in this topic from JeremyN) . It's tricky. You have to adjust the Mac Security and Privacy settings in System Preferences so the Mac will allow the Sentinel Safenet drivers to run.
swiftsketcher
Post by swiftsketcher »
Any word on Catalina compatibility on Mac?
