Hello, dear TVPaint technical support,
At first, I thought I was encountering the same issue as was described here: https://www.tvpaint.com/forum/viewtopic.php?t=10745
However, it's probably a bit different. The links from the programme to any webpages do not work (Help>User guide, Tech support etc., Check for update is greyed out as well). The difference is that when I fill in the unlock code a message "Unlock code required!" pops up. Running as administrator helped with neither the unlock code nor the links. I tried also changing preferences in firewall in vain.
I am using Windows 11 64-bits and TVPaint 11.0.0-32-bits.
Maybe I am doing something terribly wrong, but I do not know what that could be. Apart from the links and unlocking the license, everything seems to work just fine.
Thank you very much for any suggestions,
krul
Unlock code required, links not working Topic is solved
Re: Unlock code required, links not working
Hello krul,
Best,
Can you give me your lock code in a private message?The difference is that when I fill in the unlock code a message "Unlock code required!" pops up
Best,
