Trying to understand George Functions & Returns
blastframe
Post by blastframe »
I'm new to scripting with George and trying to load images from a text file. I have TVPaint requesting the import file correctly and then sending the resulting path to a function that reads the text file (based on this function from the George wiki). My issue is that when I try to store each line from the text file in a LOCAL array and return it, it doesn't print as I'd expect. If I check its values before the return, however, it prints correctly. Can George return an array? If so, can someone please help me understand how to return this array correctly? Thank you!
tv_ReadUserString fileRequest 0
parse result path
tv_ReqFile "Select file to import|"path"||*.csv"
parse result file
if (cmp(file,"Cancel") == 0)
  array1 = file_readTextFile(file)
  //set to 2 for testing purposes
  rowLength = 2
  FOR i = 0 TO rowLength
    tv_warn "array1 " i " = " array1[i]
    //returns array1 0 = array1.0
    //returns array1 1 = array1.1
    //returns array1 2 = array1.2
  END
end
FUNCTION file_readTextFile(textFilePath)
	LOCAL myReturn fileExists i line text
	tv_WriteTextFile "Exists" textFilePath
	fileExists = result
	IF CMP(fileExists,textFilePath)==1
		loop = 1
		i=0
    //while loop iterates until end of file
		WHILE loop==1
			tv_readtextfile  i textFilePath
			PARSE result line text
			IF CMP( line, "EOF"  ) == 1
				loop=0
        rowLength = i
			ELSE
				length = LEN(text)
        // length of line of text
				length=length-2
				text = CUT(text,1,length)
        //'text' variable is a line of text
        myReturn[i]=text
			END
			i=i+1
		END
	END
  	print myReturn[0]
  	//prints correctly
	RETURN myReturn
END
Hironori Takagi
Re: Trying to understand George Functions & Returns
Post by Hironori Takagi »
In my case, I would write this as:
(I am not good at using the procedure)
Is there any reason to return an array using a procedure?
parse result path
parse result file
IF CMP(file,"Cancel") == 0
	tv_WriteTextFile "Exists" file
	fileExists = result
	IF CMP(fileExists,file)==1
		loop = 1
		linecount = 0
		WHILE loop
			tv_readtextfile linecount file
			IF CMP(line,"EOF") == 1
				loop=0
			ELSE
				text[linecount] = text
				linecount = linecount + 1
			END
		END
	END
	FOR i = 0 TO linecount
		tv_warn "text " i " = " text[i]
	END
END
blastframe
Thank you for the reply, Hironori. I tend to separate things that might get reused in a script (like loading) into functions, but since there will only be one text file in this case, you're right: it doesn't need to be its own function. I find it more readable & easier to debug when different phases of the script are broken out with returns.
So is George able to return variables other than strings and numbers? I haven't found a George script with this, so I'm assuming it cannot.
Hironori Takagi
To return an array using a procedure, I think that it will be a way to PARSE in the main program by doing a CONCAT with a space in between.
There are cases where the string contains spaces, so it is troublesome to consider the correspondence.
