Strange white bar Topic is solved
- David_Fine
Strange white bar
On one scene only, I have a white bar at the top of the window, but outside the working area. I just realized it is the same bar as the Notes track, which can be displayed below, but it won't go away. I've never seen the Notes track at the top like that. How do I make it go away?
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Vancouver, Canada
Re: Strange white bar
Hi David,
Can you post a screenshot of it?
- David_Fine
Sure. This shows the notes open at the bottom with that stripe of notes on screen at the top as well. As I say, only in this scene and it happens if the scene is opened up on a different computer too.
David Fine
Vancouver, Canada
Vancouver, Canada
Hi David, it seems to me that you just activated the notes' display above the playback space:
- David_Fine
Oh wow. That is well hidden as it doesn't come up on the upper menu at all when you search for it. I've never seen it before. Thank you for solving that.
David Fine
Vancouver, Canada
Vancouver, Canada
