Hi!
I keep getting errors and I don't know how to script paper texture. I want to make it if the paper texture is on and the same, that it does nothing. If it's different or off it turns on and set the paper texture
tv_paper Hardness 82 Invert 1 Size 0.701800 Angle 0.000000 OffsetX 0.000000 OffsetY 0.000000 FlipX 0 FlipY 0 Active 1 Name "/Paper 01"
IF
THEN
tv_nop
END
What am I doing wrong? I have do this script because there's this annoying lag when hopping between eraser(no texture) and sketch pencil (texture) when drawing and accidently repressing sketch pencil causing the lag.
tv_GetActiveTool
PARSE result toolname others
IF CMP(toolname,"tv_penbrush") == 1
tv_Paper Hardness 82 Invert 1 Size 0.701800 Angle 0.000000 OffsetX 0.000000 OffsetY 0.000000 FlipX 0 FlipY 0 Active 1 Name "/Paper 01"
ELSE
tv_Paper Active 0
END
Svengali is right, in George, there's no THEN, and IF needs to be a basic true or false evaluation.
Your condition was way too complex for George, that's why it wasn't working.
Hironori Takagi's script is the correct way to do it.
Thierry wrote: ↑08 Jan 2020, 10:54
I tried the script. It doesn't seem to work. It takes a good 2 secounds when switching to my texture pencil tool. Try spamming the hotkey while stroking you can see your strokes lag when switching to texture tool pencil. Can you patch this annoying problem it's really annoying I can never use texture paper because of the annoying lag, switching and retapping the texture pencil tool. Also there seems to be a bug, it doesn't switch papers if you use .grg scripts. I address this problem for a long time and there's still hasn't been a patch for this. It needs to load faster like milliseconds. Two second lag for stroking takes forever and that's from single line of code:
It seems to work Faster if you place the Grab Tool First and the Script 2nd. But why is that? Is it programming error, when you place the Script first, then Grab Tool second? It still lags a bit.
I tried to make the script "pen <-> eraser with paper 01 texture on". If this doesn't change at once, you probably have a problem with your configuration file.
tv_GetActiveTool
tv_Eraserbrush
tv_Paper Active 0
ELSE
IF CMP(toolname,"tv_eraserbrush") == 1
tv_Penbrush "toolmode"
END
END
