Sharpen?
- Animationriver
Sharpen?
Hello!
Where is SHARPEN in TVP?
- Hironori Takagi
Re: Sharpen?
I fell into same trap.
Sharp exists in brush mode, not FX.
The method of sharpening only the stroked area is smart in a sense.
However, it is difficult for people who use other tools to understand.
Re: Sharpen?
Hironori is correct. No sharpen filter.
You can, however, sharpen the image with the CONVOLVE fx...
Also, this old thread below has some additional techniques to sharpen images. There's 3 or 4 different methods, each one quite effective depending on the situation.
http://forum.tvpaint.com/viewtopic.php?f=21&t=3576
But as Hironori said, sometimes doing it manually with the brush works the best.
TVPaint 12.0.0 Pro
Re: Sharpen?
You could maybe use erode too if it's for a line on it's own layer? Maybe.
http://www.daninski.com
- Animationriver
Re: Sharpen?
Hello!!! An elegant solution. And very secret and hidden)) Thank you so much! My thanks. Head bow.Hironori Takagi wrote: ↑14 Feb 2020, 03:51 I fell into same trap.
- Animationriver
Re: Sharpen?
WOW! Thanks!Cardin Collins wrote: ↑14 Feb 2020, 07:11 Hironori is correct. No sharpen filter.
- Animationriver
Re: Sharpen?
Hello!
Thanks. I tried. Interesting. But a little different.
Re: Sharpen?
I agree , the Sharpen mode using a brush works well for cleaning up "fuzzy" edges of lines on a drawing that has been transformed several times, but it is much too "secret and hidden" !Animationriver wrote: ↑15 Feb 2020, 14:58Hello!!! An elegant solution. And very secret and hidden)) Thank you so much! My thanks. Head bow.Hironori Takagi wrote: ↑14 Feb 2020, 03:51 I fell into same trap.
Re: Sharpen?
i now always use Michaels (Sewi) Histogram method for sharpening.
https://www.tvpaint.com/forum/viewtopic ... pen#p30040
But it is rather hidden and also not available in the standard version.
