Keyframer should "see" Layers in Multiply blend mode from another Project
This feels like a bug.
Here's the problem: I'm attempting to use the KeyFramer FX to composite an image from another .tvpp project into my current .tvpp project. I go to the Keyframer, select my other .tvpp project as the Source , but nothing shows up ... frustration ensues ... spent 20 minutes saving the projects, closing the projects, re-opening , reattempting to composite the layers using the Keyframer ... finally I think to myself: "is it because the layers from the other project are in Multiply Blend mode ?" So then I change them to Color Blend mode and then go back to the new project , and now the layers show up as expected when composited using the KeyFramer. That does not seem like it should be the case . Why can't the Keyframer "see" layers in blend modes other than normal Color mode ?
I would request that this behavior change so that when a project or layer is set as the Source in the Keyframer , it will be brought into the project by the Keyframer exactly as it is visible in the other project , whether it is in Color blend mode or Multiply, or Overlay or what have you. Or if the new layer has to also be set to Multiply then there should be a pop-up to remind the user that the blend mode of the layer must match the blend mode of the Source layer/project .
Re: Keyframer should "see" Layers in Multiply blend mode from another Project
This is a very old issue, TVPaint is not treating blendmodes in a WhatYouSeeIsWhatYouGet way.
everything is fine in the project but as soon as you export out of tvpaint or import it into another tvpproject tvpaint doen't deliver.
Xavier
Post by Xavier »
Hi, could you please provide a step-by-step scenario to reproduce this ?
Thanks in advance !
Xavier wrote: 11 Sep 2020, 16:50 Hi, could you please provide a step-by-step scenario to reproduce this ?
Thanks in advance !
Sorry , I neglected to respond to this. Here's a simple demonstration of the problem: https://www.youtube.com/watch?v=jGgvXvYBPbQ
Five layers. Four of the layers are in Multiply Blend Mode. The fifth layer is in normal Color Blend Mode.
Everything looks fine in the original project. Now I want to composite this image in another project.
I open the Keyframer and set the Source to my project with the Multiply blend modes, but only the layer
in Color blend mode shows up. The layers in Multiply blend mode are invisible to the KeyFramer.
Peter Wassink wrote: 05 Mar 2020, 14:50 This is a very old issue, TVPaint is not treating blendmodes in a WhatYouSeeIsWhatYouGet way.
everything is fine in the project , but as soon as you export out of tvpaint or import it into another tvp project tvpaint doen't deliver.
It is also the problem Peter mentions , when you try to export layers with blend modes (such as Multiply) from TVPaint , the blend modes do not show.
Try this: 3 layers , in blend mode Multiply, with 1 layer (line art) in normal Color blend mode. Export to PNG . The resulting PNG image does not have the multiply layers visible , only the line art.
But try the same thing with identical layer structure and blend modes from Photoshop and you will find that the blend modes (with transparency) are visible on the resulting export from PS.
This was exported from Photoshop , with the result that the transparent layers in Multiply blend mode are visible:
This is the same result exported from TVPaint (where did the Multiply blend mode layers go ?) --
Bump.
I was wondering if the Dev Team could respond about whether this requested improvement may be implemented soon in v 11.7.2 or v12 ?
(or if it's just not possible in the current engine ? )
Bump again.
TVPaint Developers , is it possible to fix this issue? I posted about it almost 5 years ago. (and even then Peter Wassink mentioned: "This is a very old issue, TVPaint is not treating blend modes in a 'What-You-See-Is-What-You-Get' way. Everything is fine viewed in the project, but as soon as you export out of TVPaint or import it into another TVPaint project (via the keyframer) TVPaint doesn't deliver." ).
Hello David, we have made some progress regarding this issue today, it might also be the cause for another bug we are currently fixing on the paint bucket. This still needs some investigation but we will keep users updated.
Matthieu
Post by Matthieu »
Hello David,
Like Dean said, we were talking about this today while trying to improve the Paint Bucket tool.
The issue you have mentioned is explained by the fact the Multiply mode does multiply pixel values to get new pixel values, as implied by its name.
Consequently, you can easily guess what would happen if a pixel from a layer set to Multiply mode would see its values multiplied by a non-colored, transparent pixel (of 0, 0, 0, 0 RGBA value): it will also turn into a non-colored, transparent pixel itself.
The confusion usually stems from TVPaint's default display settings which show users a "fake", white background. Preview is all fine in this case, because the "Multiply Layer"'s pixels would be multiplied by white, opaque pixels. But if you choose to export your animation / drawing without this "fake" background (by unchecking the "Background" option in the export panel), you will have effectively multiplied the "Multiply Layer"'s pixels by non-colored, transparent pixels and turned them transparent as well. Thus, in your cube example above, turning the "Background" option on in the export panel would give you the results you want.
Regading the Keyframer, having a regular Animation Layer filled with white would also make the "Multiply" Layers from your Source Project appear. However, you may not want the whole surroundings of your cube to be white, opaque pixels. In this case, what you would have to do is to use the Paint Bucket tool on an Animation Layer to fill the colored spaces on your Layers set to Multiply mode. Still, there is currently an issue with that because the Paint Bucket "Display" Source mode does not take the "fake" background into account, which makes colorizing pixels from Layers set to Multiply mode difficult. This is exactly what we were discussing today. We are now working on adding a "Display (with background)" Source option to the Paint Bucket to solve this issue.
I hope this makes things a bit more clear :)
While the mathematical explanation is correct, other software, namely PS, handles a multiplied layer on transparent as it were on white, without actually adding any white pixels on that layer.
Matthieu
Post by Matthieu »
Slowtiger: we were thinking about adding a way to do this, indeed. I would prefer allowing users to choose between those two ways of handling Multiplied layers.
Hi, Dean and Matthieu -
I'm glad to know there has been some progress on solving this issue . Thanks for the response.
Matthieu wrote: 06 Feb 2025, 14:58 Slowtiger: we were thinking about adding a way to do this, indeed. I would prefer allowing users to choose between those two ways of handling Multiplied layers.
I suppose having more options is always better , but I think because so many people are familiar with how Photoshop blend modes (including Multiply) work and most other softwares that are Photoshop alternatives (GIMP, Clip Studio Paint, etc.) more or less follow the Photoshop way of using blend modes , that it would be best to implement that way of handling blend modes in TVPaint, because there are less mental gymnastics involved for new users transitioning from the Adobe (and others) way of working with blend modes. My experience with Photoshop is that enabling blend modes on layers is truly a What-You-See-Is-What-You-Get (which is retained when you MERGE layers with blend modes or export a composite image that had blend modes applied).
It would be very important for someone like me who prefers to use TVPaint for compositing tasks to have the FX Stack tools like the KeyFramer and the Multiplane Camera able to correctly "see" the blend modes as active when using Layers or Clips as the SOURCE in Keyframer or Multiplane . This lets me have animation with blend mode layers in one project , then when I open a new project I can use the KeyFramer (with Source set to the first project) and get a composite layer (with all the blend modes applied) in the new project. Also, on those occasions where I need to use the JSON Export to port all my layers over to After Effects, it is important that any layers which have a blend mode applied will show up properly in After Effects.
