'Display XSheet tab' option in Preferences does not saved for next time
ini
Post by ini »
I use Xsheet tab currently,
and I found that option initialized next time I opened tvp.
Is it happend just to me or...
Can anybody check it out for me?
That option is in Preference>Display tab.
ini
Re: 'Display XSheet tab' option in Preferences does not saved for next time
Post by ini »
I ckecked it from friend, and It's same on his pc.
Huh, the same happens for me.
I've added it to our todo list, but don't expect this to be high priority (i.e. it won't be on the next update, maybe the one after).
//Edit: topic moved in the appropriate section
ini
Post by ini »
Thanks a lot!
If you don't mind,
I found one more on Xsheet.
I hope you check it, and also put it in todo list even if it has low priority.
When I set X-sheet sources to type-clip and set other clip in same project,
X-sheet layer shows invisible layer in source clip.
I tested it several times, and I found It occurs when the invisible layer on source clip is 'current' layer.
We can avoid it with changing set 'current layer' on source clip to other visible layers, but I hope it to be fixed...
