Clip Structure naming patterns request
spyderheart
Post by spyderheart »
Hi All,
It would be great to be able to reference the clip name and even the project name defining the folder and file name patterns under Export > Clip Structure.
Is this currently possible - to enter a pattern to insert the clip name? (I've tried "%cn" and it doesn't work...)? If not, may I gently suggest it?
Of course this could extend to many other properties one might want to reference such as layer group color, scene number, clip number, etc...
It would be great to have more of these pattern tokens as it would help me to script a one-click, error-proof, export solution to my workflow . I imagine anyone using Clip Structure would have an easier time integrating it into their own workflow with these extra pattern options.
Thanks,
David
David
TVPaint 11.7 Standard
System: 64GB RAM // 3 TB SSD // Core i7 8700K // NVIDIA GTX 1080// Windows 10 Home
Hironori Takagi
Re: Clip Structure naming patterns request
Post by Hironori Takagi »
More details about this are given below.
https://www.tvpaint.com/doc/tvpaint-ani ... estructure
As far as looking at the JSON item, the possible choices are:
"patternfolder" iPatternFolder string The pattern of the subfolder.
And they may include those special variables:
_ %li: layer index
_ %ln: layer name
_ %fi: file index
"patternfile" iPatternFile string The pattern of the files in the subfolder.
_ %li: layer index
_ %ln: layer name
_ %ii: image index
_ %in: image name
_ %fi: file index
It seems that you cannot select the clip name, clip number, scene number, layer group number, etc.
When using George, I think that it can be stored in a variable in advance and used as a prefix etc.
spyderheart
Thanks for the extra info and the tip.
I tried your suggestion of using the clip name in variable with the "patternFolder" parameter of the tv_clipSaveStructure command it it works nicely :)
David
