Hi,
There's a problem when I tried to open this project by clicking on File > Open
My TVPaint stops responding all the time.
I'm certain that the project's been saved correctly so it's quite weird and depressing why it just happened.
Here's the google cloud file.
https://drive.google.com/drive/folders/ ... p=sharing
And about my OS:
Windows 10
64 bit
Intel(R) Core(TM) i7-8750H CPU @ 2.20 GHz
2.21 GHz
16 GB RAM
TVPaint version:
10 pro (10.0.7) 32 bit
Wacom tablet:
Wacom Intuos Pro M (6.3.38-2)
I have totally no idea about the reason or the solution to this, so it would be very kind of you if you could help me check the project file out.
Thank you!!!
No respond when opening my project
Re: No respond when opening my project
Oh my, that's a very old version!
I strongly advise you to version 10.5.7 as soon as possible, by going in the Help > Check for updates main menu, and see if the problem still happens.
On sick leave until July 8th
Thanks for the reply.
While I don’t think it’s the version issue cause I’ve also tried it on TVP 11 pro(11.0.10) and it didn’t work either. (No Respond.)
Is there anything else I could try?
@Thierry, I tried with TVP 11.0.10 on Linux 64, it freezes too
