What video WILL import into TVP?
dgrantham
Re: What video WILL import into TVP?
Post by dgrantham »
THanks for the reply, Xavier. It's TVPpro 10.5.7. I know it's not officially supported, but if you can point me in the right direction it would really help.
TVPaint10Pro10.5.7-64bit :
-Lenovo ThInkpad P17 Gen2 Xeon W-11955 @2.61Ghz, 64GB, NVidia RTX A5000
-HPZ400, 6GB, NVidia Quadro 2000, Matrox MxO2
-Lenovo Legion Laptop i7700 2.8Ghz GTX1050 16GB
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
From what I've seen on my computer, among Youtube codecs :
* H.264 (Mpeg4 AVC) works
* VP9 works with TVPaint 11 but not on TVPaint 10.5
* H.265 (AV1) doesn't work
Xavier
Post by Xavier »
dgrantham wrote: 02 May 2020, 02:41 Windows 10
i7-7700HQ @ 2.8GHz
16GB Ram
I bet you're using a 64-bit architecture, right ?
Do you use the 64-bit version of TVPaint ???
dgrantham
Post by dgrantham »
None of the types of video you mention 2 posts above will work on TVP 10.5.7 in 32 or 64 bit on either of my machines.
I've been using Sorenson's default settings for Youtube output, which are shown in the below 2 images. It shows the many settings available for Sorenson's output. Not shown in the screengrabs are the available flyout options for "Codec" and "Method". They are..
Codec Flyout Options: x264, Sorenson MPEG4Pro, Sorenson H.264, Apple H.264, Main Concept H.264. Main Concept CUDA H.264
Method Flyout Options: 1 Pass VBR, 2 Pass VBR, 1 Pass CBR, 2 Pass CBR, 1 Pass CQ, Multipass, (Not all "Method" optoins are available for each Codec.)
Maybe I need to install additional 264 codecs.
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
slowtiger wrote: 09 May 2020, 19:51 Don't - use - Sörensen - Codec!
Sorenson Media is a really old set of codecs :
https://en.wikipedia.org/wiki/Sorenson_ ... chnologies
Still, your issue may be related to the fourCC header, aka the codec ID that is embedded within the video.
Sorenson Media is said to use specific fourCCs "SVQ1" and "SVQ3" for their encodings. Not sure about the other codecs you mentioned.
For a H.264 video track, the standard fourCC would be "AVC1".
All the samples you provided have their codec ID set to this value... and everyone here, who tried to import the videos, seemed to succeed.
You might use a fourCC changer. But not guarantee, and you do it at your own risk (better have a backup of the files).
In any case there is no need to fiddle with the codecs on your system : TVPaint doesn't rely on any external codec.
dgrantham
Post by dgrantham »
Thanks Xavier, I guess there could well be a Sorenson-specific issue but I think the problem is broader than that. I've never been able to load any video from any source into 10.5.7 on either of my computers.
For example, here's a link to a set of generic (as far as I can tell) MP4 Test files which I unearthed with a Google search: https://file-examples.com/index.php/sam ... mp4-files/ There's an HD file there. It plays on my Windows 10 computer, but it won't load into TVP.
Could it be that we need to look more broadly than Sorenson to get at this issue?
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
EDIT: I had a Win10 VM, so I tried installing TVPaint 10.5.7. You're right, the videos cannot be imported. Some dependencies are missing :
According to this thread, it's simply that the MS API evolved:
https://social.msdn.microsoft.com/Forum ... ncore-dlls
Which means basically that TVPaint 10 is not compatible with the new Windows versions.
Sorry, please upgrade to v11. Or else try on MacOS / Linux.
