switch off part of a layer.
ok this is probably not for the currrent engine.
i would like to be able to switch off part of a layer.
if i want to make a cut from one layer to the next, i could simply delete the extra frames.
But when i need to keep my options open i have to split the layer and this will increase the amount of layers and add to a cluttered and confusing layerpanel.
it would be nice to have a nondestructive way of switching off frames in the layer.
maybe even with opacity control to make non destructive fades!
switch of layers partially.png (67.12 KiB) Viewed 12802 times
Even fades?
sYEAH FADES---.png (25.06 KiB) Viewed 12801 times
cgmodeler
Re: switch of part of a layer.
Post by cgmodeler »
I Second that request!
www.cocoalopez.com
Desktop: TVP Pro 11.0.8 - 64bit Win 10 x64 64GB RAM - RTX3070 - Cintiq 27QHD Driver 6.3.29
Re: switch off part of a layer.
Indeed, that can't be done in the TVP11 engine :p
I think it's already in our todo list, I'm going to check and add it if it's not the case :)
ha i'm pretty sure its on the list.
it probably sits there....together with folders in the layerpanel ;-)
i'm now just reporting any issue i come across, i reason that it doesn't hurt if a request is double
Hironori Takagi
Post by Hironori Takagi »
+1.
The red line you used makes me think. In video editors and music sequencers a diagonal line like this indicates a fade.
What about making this a real feature: have a line over the thumbnails in the timeline which indicates opacity? This way we could have 1. switch off parts of the layer completely 2. have different parts of the layer have different opacity 3. can easily create fades - and all of this non-destructive, being able to edit later again and again.
This would be especially usefull for FX animation or more experimental work, and for that old technique of using less drawings with a lot of cross-dissolves.
slowtiger wrote: 15 Sep 2020, 09:29 What about making this a real feature: have a line over the thumbnails in the timeline which indicates opacity? This way we could have 1. switch off parts of the layer completely 2. have different parts of the layer have different opacity 3. can easily create fades - and all of this non-destructive, being able to edit later again and again.
Yes.
slowtiger wrote: 15 Sep 2020, 09:29 ... that old technique of using less drawings with a lot of cross-dissolves.
Stretch interpolate makes this quite easy, but yeah, to be able to do it non-destructive is something i'd love to see in TVP.
Xavier
Post by Xavier »
You now have the "delete & let empty" option available in the latest version !
For the current engine, a layer is one indivisible part. That's a workaround :)
(oops, I forgot to update the menu item names)
