No Pressure Sensitivity with Microsoft Surface Studio Topic is solved
AB3030
Post by AB3030 »
Hi there gang,
I'm using a 1st Gen Microsoft Surface Studio and unfortunately TVPaint doesn't recognise any pressure sensitivity when using the Surface Pen. Is there a driver or something I can download to sort this out? The program is otherwise completely usable, but I do miss having tapered lines....
Software: TVPaint Animation 11 (Standard Edition)
Hardware: Microsoft Surface Studio (1st gen); Intel i7 CPU @2.71 GHZ; 32 GB Ram; Nvidia GeForce GTX 980M.
Thanks for your time!
AB
Re: No Pressure Sensitivity with Microsoft Surface Studio
Hello AB,
Could you try going into the Preferences (Shift + D) and, in the General tab, change the drawing mode from Wintab to Windows Ink or the other way around and see if this changes anything, please?
AB3030
Post by AB3030 »
Worked like a charm! So pleased it was an easy fix (and quite surprised it didn't come up during my extensive googling)
Really appreciate the help, Dean, thank you!
