I bet some of what I'm requesting may already exist. One of the things I was going to mention was regarding the Filled Stroke eraser and Selection tools. Then I suddenly realized the you could use right click to erase/sub
1. Warp Grid fix as discussed here https://www.tvpaint.com/forum/viewtopic ... 10&t=13674 with a great addition by Peter Wassink.
2. The ability to group layers into folders instead of just changing colors.
- I imagine this is an issue for lots of other users since the timeline can get super heavy
- I'm basically using Photoshop as a point of reference
- And to use an example of how it would be useful. I'll have twelve layers for one animation sequence that requires them to be split. Merging is not an option. Those twelve layers take up a lot of real estate.
- I'm not sure why it's off by default
- When you have two layers selected and right click, the options for Delete and Duplicate are there. But adding the Merge options would be a great help in streamlining workflow.
- The ability to have two windows. One for the Palette and one for the Slider. Again, maybe this is nit picky but it's annoying not to have this ability.
- This is one that I think is super important. I use the Flip FX often and it's a bit of workflow pain when I constantly have to use the FX panel.
- It would be great to have the ability to select the sequence, right click and flip.
- Now, this may not be possible with how TVP is programmed but I would love the addition if possible.
If there's a way to participate in the beta versions, please let me know.
