Brush tool lagging
mcohen23
Brush tool lagging
Post by mcohen23 »
My brush tool is lagging when I increase the speed of my stroke. This only seems to happen when the pressure sensitivity is on. I contacted the company and they said to try and launch it in low resolution mode, but I can't figure out how. Any help would be appreciated!
artfx
Re: Brush tool lagging
Post by artfx »
Are you on the Mac?
Terrence Walker
MacOS Monterey Version 12.6.2
mcohen23 wrote: 03 Apr 2020, 21:17 I contacted the company and they said to try and launch it in low resolution mode, but I can't figure out how.
In Applications, right-click on the TVPaint application , choose Get Info. Put a check mark next to Open in Low Resolution.
HannuriYu
Post by HannuriYu »
I don't know this helps but I'm sharing what I found out.
I'm using mcbook pro 16" with 32GB memory and the best graphic card choice. I recently found I have an issue with lagging when I draw. It wasn't in high resolution setting and also not special brush.
It was just basic pen brush on 1920x1080 drawing panel.
The thing is that I didn't have lagging issue before but it happened just a month ago suddenly. I thought it's because of recent upgrade of TVPaint but there is no way to download previous version.
I thought maybe it's memory issue so that I raise usage of memory up to 24gb only for TVPaint in preference. but it's still lagging. I was frustrated.
Then I thought it's weird that the lagging issue came from nowhere suddenly even if I didn't change any software or hardware since I bought Mcbook pro in March.
I found one difference. It is multi screen. A month ago, I bought extra high resolution monitor for having enough screen room. Before I purchase monitor, my display setting was mirror mode (every screen is same screen) and I didn't have lagging issue. As soon as I noticed, I turned off the monitor and change display setting into 'mirror mode'. Then boom, no lagging even if how fast I move my brush. I think issue is coming from having multiple screens. Since every screen has different color, resolution limit and setting on its own, computer itself may take more time to calculate things than having just one screen setting. I'm not a computer guy. This is just my thought.
I attach screenshot images. you could have better resolution when you optimize your screen on your Cintiq.
I will use mirror mode when I use TVPaint from now on. I hope everybody solves lagging problem with this.
vaughan-ls
Post by vaughan-ls »
Are there any updates on this?
Mirroring the display works, but I need to see my other screen.
Xavier
Post by Xavier »
As said before, the higher the resolution the more pixels TVPaint has to deal with... so yes, working in HD has a cost.
Monsieur U
Post by Monsieur U »
Hi I'm having the same issue on my somewhat old Imac (3,4 Ghz core i7, 16Go RAM, GPU ATI Radeon 4850 512 Mo, running on OSX 10.11.6), with a wacom cintiq 16.
Th way I found to mitigate the problem is to set the resolution of the cintiq at 1080p. Some lag still happen but not as often as on higher resolutions. I've just dowwnloaded TVP STD 11.0.10 but I cannot find the option you refer to as " new settings that allows 'rolling back to the previous version drawing mode' on the Mac version." Where can I find this please ?
Now it's a shame to have a 4K display and not being able to use it at its fullest, so any solution to at least be able to switch to a higher res without working on a slideshow would be appreciated !
Hello, I sent you a link via PM ;)
Monsieur U
PM back :)
Xavier
Post by Xavier »
Monsieur U wrote: 19 Nov 2020, 14:29 Now it's a shame to have a 4K display and not being able to use it at its fullest, so any solution to at least be able to switch to a higher res without working on a slideshow would be appreciated !
As explained previously, more pixels on the screen mean more pixels to manage by TVPaint. The lag is like a traffic jam of data !
You'd need to upgrade to the latest version (available in your TVPaint account) to have the switch, it's not in the v11.0.10.
PaulBushArt
Post by PaulBushArt »
Xavier wrote: 19 Nov 2020, 20:58 You'd need to upgrade to the latest version (available in your TVPaint account) to have the switch, it's not in the v11.0.10.
I'm curious about this statement as 11.0.10 is the latest version I have in my account download? Is there a newer version available?
Thanks,
daninski
Post by daninski »
I know I keep reading this, but I made my film in4k with no brush lag in an older version of TVP11 pro on the mac, with the updated version it has trouble with standard HD, so I think the explanation that more pixels = more work is applicable in this situation as an explanation. It's clear something in the updates has created the hard work.
http://www.daninski.com
I'd like to add as data point that I don't experience any brush lagging while working in 4K in TVP 10.5 on a 2008 Mac Pro with 8 GB RAM in OS 10.6.8.
Xavier
Post by Xavier »
Ok, sorry I was obviously too quick to answer : it's not especially about the screen resolution but rather the screen density, aka Retina
Tell me if I'm wrong : the previous versions work in "non-Retina" (so called "low resolution") mode, right ?
daninski
Post by daninski »
I animated 4k on a 2019 MacBook pro with a retina, and an iMac 32" 2013 without. No lag with either of them on the old version. Both have lag with the new version.
