Hello there.
I have used TVP10 for quite a while and one of my favorite features was that If I held my finger on the shortcut on the pen stylus (color picking shortcut) then I could select the B color, as opposed to the A color that comes from a single click on the shortcut. This was exceptional for LUMA brushes which I use to paint with.
But when I try it on TVP11 it doesnt seem to work. I have everything set out the same. I am using the trial version for testing.
Did this aspect change or am I doing something wrong?
ColorPicking 2 colors A and B
Re: ColorPicking 2 colors A and B
check keyboard short-cuts and make sure this function
Color: Color Picker B Color is assigned to a key
; is the default short cut for A pen Color picker
you could create a shortcut for the B pen and assign that to your pen switch.
make your wacomswitch activate the assigned short-cut key
