TVPaint 11.5 crashes if I use the new fullscreen shortcut
schwarzgrau
Re: TVPaint 11.5 crashes if I use the new fullscreen shortcut
Post by schwarzgrau »
This is weird: I assigned Hide/Show All Drawers to J on my other Windows machine and it does the same. I hit the key and TVPaint closes, no matter if there are unsaved changes. This has probably something to do with my settings, but I can't see which. On my Mac I've already set the keyboard shortcuts to default, to be sure there isn't a conflict, but the problem persists. The weird thing is, that this happens on my Windows PC too.
Xavier
Post by Xavier »
schwarzgrau wrote: 20 Dec 2020, 11:44 Could you tell me how I reset my whole TVPaint configuration to default?
The procedure is explained right here : viewtopic.php?f=10&t=13894&p=122158&hil ... ta#p122158
If you're willing to reset your configuration to default, I'd say that you can just delete all the tvp* folder (or move it to a backup ^^)
Xavier
Post by Xavier »
schwarzgrau wrote: 20 Dec 2020, 13:45 This is weird: I assigned Hide/Show All Drawers to J on my other Windows machine and it does the same. I hit the key and TVPaint closes, no matter if there are unsaved changes. This has probably something to do with my settings, but I can't see which. On my Mac I've already set the keyboard shortcuts to default, to be sure there isn't a conflict, but the problem persists. The weird thing is, that this happens on my Windows PC too.
Which build date shows up in the about window ? It should be 2020/12/08.
