Hello, I'm new to TVpaint. When I select a drawing and click on the transform tool, the drawing flips at a random angle and goes away at a random distance.
What can I do to fix this?
Thanks
A problem with the transform tool Topic is solved
Re: A problem with the transform tool
Not sure why the angle is changing on you , but try this:
Click RESET on the Transform Tool. That should re-center it . Then try transforming it again.
D.T. Nethery wrote: ↑28 Dec 2020, 22:39Not sure why the angle is changing on you , but try this:
Meanwhile, the problem got solved on its own somehow. I guess I changed some settings without even noticing. But if it'll happen again, I'll try this solution. Thanks!
TVpaint 11.5 Standard, Windows 10 64-bit, i5-5200U
