not detect sensitivity without WinInk
So atm it appears I can't have pen sensitivity without turning on 'WindowInk' in wacom preference.
(I'm using rather old tablet that requre rather old driver to run properly).
but if I turn the WindowInk on then I can't do alt+RMB for zooming in and out , anyone having same issue? kinda shame having to run into this after 7 years of having such dependable software.
Re: not detect sensitivity without WinInk
Oh, btw I'm using
-Window10
-TVPaint 11.5 64Bit Standard Edition
-Window10
is it in TVPaint only ?
yes, other software in my PC such as Clipstudio , Blender(GreasePencil) and Photoshop don't have the same issue.
and I made sure to open only one software at a time.
Ok, please open the about window in TVPaint. Which build date is it ?
the version is 11.5.0-64 bits
I think he is asking for the date of the build . Go to Help Menu > About TVPaint Animation > look at the build date at the top of the window that opens after you click on About TVPaint Animation.
Thanks ! yes, that was actually the questionD.T. Nethery wrote: ↑22 Dec 2020, 19:36 I think he is asking for the date of the build . Go to Help Menu > About TVPaint Animation > look at the build date at the top of the window that opens after you click on About TVPaint Animation.
sorry for late reply, the version was from Dec 08 2020.
Since its not appear to be any plan on early fixes would it be possible to roll back to older version before december?
Hello, I saw that you turn on Win Ink in the Wacom driver, but have you tried turning it on in the General tab of the Preferences in TVPaint while keeping it unchecked in the Wacom driver?
Yes I've tried fumbling with all the option even restart the program every time I made changes in preference, and right now instead of going back and forth in this forum I really need to get work done, is there no way to roll back to older version for now?
I sent it to you via PM
Also, which table model are you using?
So you say that in the older versions it was different ?
Please let us know if it's okay for you with TVPaint 11.0.10. There is maybe something to fix on the 11.5.0.
unfortuntedly the problem still persist, I'm starting to suspect something in Window updates instead.Xavier wrote: ↑30 Dec 2020, 11:48So you say that in the older versions it was different ?
I'll test it on other pc and keep you guys posted, appreciate helps and support so far.
