lazy-brush doesn't work for some reason Topic is solved
dudulala
Post by dudulala »
It seems like it only works on stroke i draw within tvp,but it doesn't work on images I imported as footage.(I click "paint",no reaction)i use TGA image,so I wonder maybe lazy-brush have some kind of image type limitation? however i couldn't find such information everywhere.
Re: lazy-brush doesn't work for some reason
dudulala wrote: 29 Jan 2021, 15:32 It seems like it only works on stroke i draw within tvp,but it doesn't work on images I imported as footage.(I click "paint",no reaction)i use TGA image,so I wonder maybe lazy-brush have some kind of image type limitation? however i couldn't find such information everywhere.
Are the images you imported transparent ? (like TGA or PNG with alpha channel ? ) IF the images are not transparent then you will first need to run the scan cleaner to remove all the white pixels. FX Stack > Color > Scan Cleaner.
https://www.tvpaint.com/doc/tvp11/index ... lack-white
dudulala
Post by dudulala »
thankyou D.T. Nethery!
problem solved!
