Instance renaming
tribute27
Instance renaming
Post by tribute27 »
Is there a way to rename only the instances of the same name? I would like to rename all the potentially empty instances to '0'
Screenshot 2021-02-04 120203.png (13.29 KiB) Viewed 6942 times
Re: Instance renaming
tribute27 wrote: 04 Feb 2021, 22:14 Is there a way to rename only the instances of the same name? I would like to rename all the potentially empty instances to '0'
To rename a single instanced right-click on the selected instance . From the menu select Rename > Selected Instance.
Screen Shot 2021-02-04 at 5.04.31 PM.jpg (49.73 KiB) Viewed 6932 times
If you want more control over renaming multiple instances , get a custom tool panel made by Mads Juul called Tracker_Panel , here: viewtopic.php?f=11&t=7132&p=120603
There's an updated version of it here: viewtopic.php?f=11&t=7132&p=120603#p116222
tribute27
Post by tribute27 »
D.T. Nethery wrote: 04 Feb 2021, 23:59
Not quite what I was looking for but it's appreciated! I was thinking more of if I rename an instance, it would affect all other instances with the same name. The second link does eliminate a step of that process though, so much thanks!
tribute27
Post by tribute27 »
Ended up making my first script for it! Was a great learning experience as I spent hours back and forth between Juuls Tracker, MJs Clip Batch Rename and tvpaints george documentation site tryna figure out how everything worked (thank you so much).
When I press cancel on it, it give renames everything to 'Cancel' lol. but otherwise it works as I want it to. was pretty satisfying trying to figure out the code to suit my own needs.
InstanceCopiesRename.grg
(914 Bytes) Downloaded 643 times
ini
Post by ini »
tribute27 wrote: 05 Feb 2021, 08:56 it give renames everything to 'Cancel' lol
You can avoid that with this, check attachment
tv_ReqString "Set New Instance Name|"""
if cmp(result,"Cancel")
else
//the code you want to run
end
InstanceCopiesRename_AvoidCancel.grg
(958 Bytes) Downloaded 581 times
tribute27
Post by tribute27 »
ini wrote: 06 Feb 2021, 00:58
else
end
:OOO Splendid! Thank you so much!
