Brush Creation Help
LuisVital
Brush Creation Help
Post by LuisVital »
Hello, im looking for some help recreating this procreate brush in tvpaint, been using it alot and i would to animate something more complicated with it.
it has this weird hue automatic variation when paiting.
https://imgur.com/a/l7yNFj2
Re: Brush Creation Help
a tip would be to create a black and white (greyscaled) custombrush (animated or not) as your basis and set the stamp mode of the tool to Luma.
that way it will channel the A and B colors selected in the colorpanel through the white and black pixels (respectively) of the brush.
LuisVital wrote: 21 Jan 2021, 13:15 Hello, im looking for some help recreating this procreate brush in tvpaint, been using it alot and i would to animate something more complicated with it.
Here is a post that discusses the basic procedure for recreating a brush, in this case from Corel Painter.
I don't know if this would also work for recreating a ProCreate brush, but it might get you started.
https://forum.tvpaint.com/viewtopic.php?f=11&t=1537
This was from Hisko Hulsing, regarding a brush he and Peter Wassink recreated in TVPaint.
this brush
"I made a screenshot of the Painter brush, and imported the image in TVPaint and added paper and pressure for the opacity.
I'm working with the brush right now and it feels even better than the one in Painter."
1. Select a brush in Painter or Photoshop.
2. Make a new document and zoom in until the form of the brush is big and clearly visible
3. Place your mouse or pen above the white canvas (or whatever)
4.make a screenshot (when you are still in Painter or Photoshop)
chalk_brush_painter_screenshot (1).jpg (13.73 KiB) Viewed 37542 times
5. Open a document in TVPaint and than: Edit - Clipboard - Get brush from clipboard
(NOTE: in TVPaint 11/11.5 this will be Edit > Clipboard > Paste Image )
6. place the brush by clicking on the canvas in TVPaint (if you use TVPaint 11.5 Edit > Clipboard > Paste Image
the brush image is already placed on the canvas at this point)
7. Turn the white pixels into transparent by: FX Stack > Color > Scan Cleaner B&W
8. fill the Brushform with black using the Paintbucket fill tool.
9. Use the Cut Brush tool to pick the shape up as a Custom Brush.
10. Play around with the settings of the Custom Brush (this can include
adding paper).
11. We looked at the behaviour of the brush in Painter and decided to put the angle on D (direction) and a jitter of 17% (to give it a more fuzzy random look) and pressure for 56% opacity.
We didn't use the profile editors, but if you want you can also edit those with graphs.
12. Copy and Paste the Custom Brush to a new Custom Panel. "
Attached is the Naturalistic Chalk Brush as a .tvpx file.
Naturalistic Chalk Brush.tvpx
(153 KiB) Downloaded 1663 times
oh dear... almost 14 years ago :shock:
to use Hisko's 'chalk brush' shape as example...
by painting it B/W and setting the stamp mode to Luma, you can channel the A and B colors to your liking.
so i colored the shape like this: and this is the cutbrush that forms the basis for the brush
There are hardly limits to choosing shapes and b/w variations other then your inspiration... so just experiment!
and not just the shape but also all the brushpanel settings en connection settings.
i didn't even adress the possiblities that open up if you make it an animbrush,
Then you can think about animating the shape of the brush itself or just the b/w pattern ...or both.
this animation then in turn can be connected to a range of input variables like pressure speed direction etc...
Screenshot 2021-02-10 235339.png (135.78 KiB) Viewed 37530 times
tvpx with the brush:
sponge.tvpx
(376 KiB) Downloaded 1693 times
Peter Wassink wrote: 11 Feb 2021, 00:28 oh dear... almost 14 years ago :shock:
Yeah ... I couldn't really find anything else that explained the process as well as that post from Hisko.
(thanks for the additional info in your next two posts, above)
oscar
Post by oscar »
Thank you for the advise, I really like what the luma setting allows to do!
I just have a tiny problem, that switching from alpha stamp to luma, makes my brush very transparent. I don't really understand why tho... Any pointers? The brush I'm speaking about is this one. I'd really appreciate it, thank you!
