With images stored in the Image Library we currently have options to Create New Project From Image and Create Custom Brush From Image .
I am requesting that an option be added for Create New Clip from Image.
Even better: Create New Clip from All Selected Images. So, for example , if I have 25 images in the Image Library and select them all , 25 new Clips are created . If I only selected 9 of the 25 images then 9 new clips are created.
I think this would be possible because if we can Create a New Project from Image , why not Create New Clip from Image ?
Image Library - Create New Clip from image
Re: Image Library - Create New Clip from image
That's a good idea indeed!
I'll add it to the list.
Hi David, just wondering : how would these 25 clips be created ?D.T. Nethery wrote: ↑26 Feb 2021, 16:29 With images stored in the Image Library we currently have options to Create New Project From Image and Create Custom Brush From Image .
- in the current shot scene ?
- in a new shot scene ?
- all in the same shot scene ?
- each clip in a different shot scene ?
do you mean scene vs clip?
(shot is not a thing in tvpaint.
i think separate scenes makes most sense as this library to timeline step, would usually be done to get a storyboard into tvpaint.
then the user would have to group them into scenes and/or clips manually.
But maybe its possible to look at the file name?
So that TVP will look in the library if the images are named according to a convention...
for instance:
sc001_sh008 & sc001_sh009 these would be put in the same scene.
And also, you'd want images to be in the same clip because usually in a storyboard each shot(clip in tvp) will have a couple of storyboard images
But to customize this process would require something like the current "Layer Preset manager",
a "Scene import manager " if you will, so users can set tvpaint to group a library import according to their wishes.
So that when you import a batch of storyboard drawings from the library they will be connected into scenes according to the users panel naming convention.
for instance:
Yeah, sorry I updated my previous message.
To me the "shot" (or the scene) is the kind of grey cell into which the clips are wrapped.
i'd like a "Scene import manager" where you can set yourself how tvpaint should import the library
a panel something like this, where you can set what filenames should be grouped into scenes:
- scene import preset panel example.png (26.09 KiB) Viewed 13401 times
This is nice Peter, but I won't have time to do it for the 11.5.2, which is expected for the end of the month. Could you please post your proposal in a separate topic ?Peter Wassink wrote: ↑15 Jun 2021, 12:18i'd like a "Scene import manager" where you can set yourself how tvpaint should import the library
will do.
Ok, I spent a few days trying to create a new clip using an image from the library ; and I face difficulties.
So I will save this one for later, we'd need a good code cleanup before I can manage to do this. I need to dive deeper into the code.
