Some TVP 10 scripts don't work in TVP 11 Topic is solved
I wrote a bunch of George scripts in TVPaint 10 that no longer work in TVPaint 11. Is there a list of changes that I can look into so I know where to start to fix them?
- LukasKrepel.nl
- TVPaint Pro 11.7.5
- MacBook Pro i7 2018 macOS Sonoma 14.6.1 + PC Windows 10
- Wacom Cintiq 27QHDT + Wacom Intuos4
- YouTube.com/@ClubBaboo
- YouTube.com/@FrameOrder
Re: Some TVP 10 scripts don't work in TVP 11
I always use Lukas' scripts. They work really well and they save me a lot of work.
However, a lot of them are broken now. So any help from the TVP team would be really helpful!
Thanks
Thanks
TVP Pro 11.7.1
TVP Pro 11.7.1
Can you post the scripts (or send them to me via PM if you don't want them to be available to the public), so I can check what's wrong?
I don't think we changed a lot of commands in v11 updates, as we know that it might break already existing scripts, we mainly added new ones.
You can check the changelogs: viewtopic.php?f=10&t=9058Is there a list of changes that I can look into so I know where to start to fix them?
Hi Thierry,
Nothing serious in the changelog that I can imagine is breaking the scripts. For some scripts I can imagine some tool settings have changed, but it might be something else.
Here's an example script that no longer works:
The scripts saves a layer's blending mode to the layer name, for example: A layer "Shadow" might become "Shadow_Multiply", so when someone works on the file without TVP Pro (our interns usually work on TVP 11 non-pro), that information doesn't get lost. And when someone with pro opens the file, the script sets the blending mode back to the original state.
Thanks for looking into it
// Fix multiply stuff from non-pro .tvpp files
Blendingmode[1] = "Color"
Blendingmode[2] = "Behind"
Blendingmode[3] = "Erase"
Blendingmode[4] = "Shade"
Blendingmode[5] = "Light"
Blendingmode[6] = "Colorize"
Blendingmode[7] = "Hue"
Blendingmode[8] = "Add"
Blendingmode[9] = "Sub"
Blendingmode[10] = "Multiply"
Blendingmode[11] = "Screen"
Blendingmode[12] = "Replace"
Blendingmode[13] = "Copy"
Blendingmode[14] = "ReplaceSet"
Blendingmode[15] = "Difference"
Blendingmode[16] = "Divide"
Blendingmode[17] = "Overlay"
Blendingmode[18] = "Light2"
Blendingmode[19] = "Shade2"
Blendingmode[20] = "HardLight"
Blendingmode[21] = "SoftLight"
Blendingmode[22] = "GrainExtract"
Blendingmode[23] = "GrainMerge"
Blendingmode[24] = "Sub2"
Blendingmode[25] = "Darken"
Blendingmode[26] = "Lighten"
Blendingmode[27] = "Saturation"
tv_undoOpenStacktack
tv_LayerCurrentID
Beginlayer = result
layerRun = 1
layerPos = 0
WHILE layerRun
tv_LayerGetID layerPos
lid = result
IF CMP(lid,"NONE")==0
//---START RUN ON LAYER---
//PARSE LAYER INFO
tv_LayerInfo lid
PARSE result layerDisplay layerPosition layerOpacity LayerName layerType layerStart layerEnd layerPrelighttable layerPostlighttable layerSelection
//REPLACE SPACES IN LayerName BY UNDERSCORES
PARSE LayerName LayerName1 LayerName2 LayerName3 LayerName4 Layername5
IF CMP(Layername5,"")==0
PRINT "This layername has too many spaces: "LayerName
END
IF CMP(LayerName4,"")==0
LayerName = LayerName1"_"LayerName2"_"LayerName3"_"LayerName4
ELSE
IF CMP(LayerName3,"")==0
ELSE
IF CMP(LayerName2,"")==0
END
END
END
lastUnderscore = LastPos(LayerName,"_")
strlen = LEN(LayerName)
LastWord = RightString(LayerName,strlen-lastUnderscore)
IF CMP(lastUnderscore,0)
FirstPart = LayerName
ELSE
FirstPart = LeftString(LayerName,lastUnderscore-1)
END
FOR i = 2 TO 27
//CHECK LAYERBLENDING AND SET NAME TO MULTIPLY
tv_layerblendingmode lid
IF CMP(result,Blendingmode[i]) && CMP(LastWord,Blendingmode[i])==0
LastWord = Blendingmode[i]
LayerName = LayerName"_"LastWord
tv_LayerRename lid LayerName
ELSE
LayerName = FirstPart"_"LastWord
END
END
//SET LAYER TO BLENDINGMODE IF NAME IS BLENDINGMODE
IF CMP(LastWord, Blendingmode[i])
tv_layerblendingmode lid Blendingmode[i]
END
tv_layerblendingmode lid LastWord
END
//---END RUN ON LAYER---
layerPos = layerPos+1
ELSE
layerRun = 0
END
END
tv_layerSet Beginlayer
tv_undoCloseStack
#INCLUDE "Include.grg"
- LukasKrepel.nl
Can you send me the "include.grg" script that is referenced in your script?
Also, if you could post a screenshot of the error message you're getting it would be great
From what I've seen so far, it seems you're missing the two Blending Modes we've added in v11: Overlay2 (in v11.0.3), and Alpha Diff in (v11.0.9). This might affect the loop at line 78 (FOR i = 2 TO 27).
Oh, of course, I didn't realise it was being included:
// *** FIRST PART ARE FUNCTIONS BY LUKAS KREPEL (FRAME ORDER) ***
// *** THE REST OF THE FILE IS MADS JUUL'S INCLUDE FILE WITH ALL BASIC/ADVANCED/USER FUNCTIONS ***
// *** Hide storyboard and overlay layers
// *** Wordt in geen enkel script gebruikt, voor backup purposes staat ie hier.
FUNCTION HideStoryboardAndOverlayLayers()
tv_layercolor hide Display 12 // Hide Storyboard layer before rendering
tv_layercolor hide Display 11 // Hide Overlay layer before rendering
END
// *** Render images and save XML
FUNCTION ExportImagesAndXML(saveDir, clipName, inpoint, outpoint, clipOffset)
renderStart = inpoint
renderEnd = outpoint
offsetSTART= renderStart - inpoint + 1
offsetEND = renderEnd - inpoint + 1
// *** Get info
//todo
//tv_clipname ClipID
//renderName = result
ClipXMLfile = saveDir"/"clipName".xml" //!!!!!!!!!!!!!!!!!!
sequenceIn = inpoint + 1
sequenceOut = outpoint + 1
// *** Write info
XMLbegin(ClipXMLfile, clipName, sequenceIn, sequenceOut, projectFramerate)
// *** Start saving image files
curImage = renderStart
WHILE curImage <= renderEnd
tv_layerImage curImage
offsetImage = curImage - inpoint + 1
frame = offsetImage + renderStart
prefixedFrame = addZeros("_",frame,5)
fileName = clipName""prefixedFrame""ext
filePath = saveDir"/"fileName
//Show message
Message = CONCAT("Rendering all clips with XML file | ", (filePath))
tv_lockdisplay Message
frameEnd = frame + 1 //todo
OffsetFrame = frame + clipOffset
filePathWithQuotes = '"' filePath '"' //Enclose path-filename with (single quote double quote singlequotes)
//Save image file
tv_ProjectSaveSequence filePathWithQuotes CAMERA OffsetFrame OffsetFrame
frameStart = frame
tv_exposureNext //Goes to next exposure
curImage = result
// *** Find next frame
frameEnd = frame
// *** Check if we reached the last frame
tv_exposureinfo curImage
PARSE result type rest
XMLimage(ClipXMLfile, fileName, filePath, frameStart, frameEnd, projectWidth, projectHeight, 0) //todo moet ClipXMLfile een parameter zijn?
XMLimage(TotalXMLfile, fileName, filePath, frameStart, frameEnd, projectWidth, projectHeight, addsomeframes) //todo TotalXMLfile bestaat niet altijd, alleen als je meerdere clips rendert, checken op null?
IF CMP(type,"Head")==0 || curImage >= sequenceOut //todo OF ALS we verder zijn dan outpointje
addSomeFrames = addSomeFrames - inpoint - 1 + frameEnd
curImage = renderEnd + 1
END
END
XMLend(ClipXMLfile)
END
// *** Set layers named "*_Multiply" to multiply. And name all multiplied layers "*_Multiply"
FUNCTION FixMultiply()
Zoekwoord = Multiply
tv_LayerCurrentID
beginLayer = result
layerRun = 1
layerPos = 0
WHILE layerRun
layerID = result
IF CMP(layerID,"NONE")==0
// START RUN ON LAYER
tv_LayerInfo layerID
PARSE result layerDisplay layerPosition layerOpacity layerName layerType layerStart layerEnd layerPrelighttable layerPostlighttable layerSelection
last = LastPos(layerName,"_")
strlen = LEN(layerName)
IF CMP(last,0)
Eerstewoord = layerName
ELSE
Eerstewoord = LeftString(layerName,last-1)
END
Tweedewoord = RightString(layerName,strlen-last)
IF CMP(Tweedewoord, Zoekwoord)
tv_layerblendingmode layerID Multiply
END
IF CMP(result,Multiply)
Multiplylayername = Eerstewoord"_Multiply"
tv_LayerRename layerID Multiplylayername
END
// END RUN ON LAYER
ELSE
layerRun = 0
END
END
tv_layerSet beginLayer
END
// *** Add a prefix and extra zeros to a number, to turn "2" into "_00002" for example (Different than Mads Juul's version, can't remember why)
FUNCTION addZeros(prefix,number,digits)
LOCAL current i
current = LEN(number)
digits = digits - 1
FOR i = current TO digits
prefix = prefix"0"
END
prefix = prefix""number
RETURN prefix
END
// *** Write start of XML file
FUNCTION XMLbegin(XMLfile, sequenceName, sequenceIn, sequenceOut, projectFramerate)
tv_WriteTextFile "Create" '"'XMLfile'"' "<xmeml version="'"4"'">" //klopt
sequenceNameWithQuotes = '"'sequenceName'"'
tv_WriteTextFile "Append" '"'XMLfile'"' "<sequence id="sequenceNameWithQuotes">" //SEQUENCE NAME (moet tussen quotes?)
tv_WriteTextFile "Append" '"'XMLfile'"' "<uuid>69b229de-c9e4-410e-869c-c77e560b4e18</uuid>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<name>"renderName"</name>" //SEQUENCE NAME
tv_WriteTextFile "Append" '"'XMLfile'"' "<duration>0</duration>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<rate>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<timebase>"projectFramerate"</timebase>" //FRAMERATE
tv_WriteTextFile "Append" '"'XMLfile'"' "<ntsc>false</ntsc>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</rate>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<in>"sequenceIn"</in>" //IN
tv_WriteTextFile "Append" '"'XMLfile'"' "<out>"sequenceOut"</out>" //OUT
tv_WriteTextFile "Append" '"'XMLfile'"' "<timecode>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<string>00:00:00:00</string>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<frame>0</frame>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<displayformat>NDF</displayformat>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</timecode>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<media>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<video>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<format>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<samplecharacteristics>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<width>"projectWidth"</width>" //PROJECT WIDTH
tv_WriteTextFile "Append" '"'XMLfile'"' "<height>"projectHeight"</height>" //PROJECT HEIGHT
tv_WriteTextFile "Append" '"'XMLfile'"' "<pixelaspectratio>square</pixelaspectratio>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<anamorphic>false</anamorphic>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</samplecharacteristics>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</format>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<track MZ.TrackName="'"video"'">"
tv_WriteTextFile "Append" '"'XMLfile'"' "<enabled>true</enabled>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<locked>false</locked>"
end
// *** Write middle part of XML file, for each image
FUNCTION XMLimage(XMLfile, fileName, filePath, frameStart, frameEnd, width, height, addsomeframes)
frameStart = frameStart - inpoint - 1 + addSomeFrames
frameEnd = frameEnd - inpoint - 1 + addSomeFrames
fileNameWithQuotes = '"'fileName'"'
tv_WriteTextFile "Append" '"'XMLfile'"' "<clipitem id="fileNameWithQuotes">" //FILENAAM (moet tussen quotes?)
tv_WriteTextFile "Append" '"'XMLfile'"' "<masterclipid>"fileName"</masterclipid>" //FILENAAM
tv_WriteTextFile "Append" '"'XMLfile'"' "<name>"fileName"</name>" //FILENAAM
tv_WriteTextFile "Append" '"'XMLfile'"' "<duration>25</duration>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<timebase>25</timebase>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<start>"frameStart"</start>" //STARTFRAME
tv_WriteTextFile "Append" '"'XMLfile'"' "<end>"frameEnd"</end>" //EINDFRAME
tv_WriteTextFile "Append" '"'XMLfile'"' "<in>0</in>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<out>25.0</out>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<alphatype/>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<pixelaspectratio/>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<anamorphic/>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<file id="fileNameWithQuotes">" //FILENAAM (moet tussen quotes?)
tv_WriteTextFile "Append" '"'XMLfile'"' "<name/>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<pathurl>"filePath"</pathurl>" //filePath
tv_WriteTextFile "Append" '"'XMLfile'"' "<width>"projectWidth"</width>" //RESOLUTIE.X
tv_WriteTextFile "Append" '"'XMLfile'"' "<height>"projectHeight"</height>" //RESOLUTIE.Y
tv_WriteTextFile "Append" '"'XMLfile'"' "</video>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</media>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</file>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<labels>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<labels/>"
tv_WriteTextFile "Append" '"'XMLfile'"' "<label2>"colorLabel"</label2>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</labels>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</clipitem>"
END
// *** Write end of XML file
FUNCTION XMLend(XMLfile)
tv_WriteTextFile "Append" '"'XMLfile'"' "</track>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</sequence>"
tv_WriteTextFile "Append" '"'XMLfile'"' "</xmeml>"
END
// *** Delete all invisible layers (necessary before merging, otherwise they won't be merged)
FUNCTION DeleteInvisibleLayers()
tv_LayerCurrentID
beginLayer = result
layerRun = 1
layerPos = 0
WHILE layerRun
layerID = result
IF CMP(layerdisplay, "OFF")
tv_layerKill layerID
layerPos = layerPos-1 //Layer has been deleted, so we need to make sure the next layer does not get skipped.
END
// END RUN ON LAYER
ELSE
layerRun = 0
END
END
END
// *** BELOW THIS PART IS MADS JUUL'S INCLUDE FILE ***
// Mads Juul INCLUDE file includes the functions from the basic.grg and the advanged.geg George files as well as the proceduresmade by users found in the wiki
// http://wiki.tvpaint.fr/index.php?title=George_Command_Reference
// Use at your own risk!
//{{{ BASIC
//{{{ Find(string,car,start)
// Find
// Function: find a character into a string
// from a specified start position
// Call: Find(string,car,start)
// Arguments:
// string = characters string
// car = character to look for
// start = start position in string
// Return: position of character
// 0 if character does not exist
// into string
// -1 if invalid position
// (negative, null or higher
// than string length)
FUNCTION Find(string,car,start)
LOCAL i size
i = start
size = LEN(string)
IF ((start <= 0) || (start > size) || (CMP(car,"") == 1))
RETURN -1
END
DO
IF (CMP(CHAR(string,i),car) == 1)
RETURN i
END
UNTIL ((i=i+1) > size)
RETURN 0
END
//{{{ FirstPos(string,car)
// FirstPos
// Function: find first occurence of a
// character into a string
// Call: FirstPos(string,car)
// Arguments:
// or 0 id character does not
// exist into string.
FUNCTION FirstPos(string,car)
RETURN Find(string,car,1)
END
//{{{ LastPos(string,car)
// LastPos
// Function: find last occurence of a
// Call: LastPos(string,car)
// Arguments:
// or 0 if character does not
FUNCTION LastPos(string,car)
LOCAL loop myChar
pos = LEN(string)
loop = 1
WHILE loop
myChar = CHAR(string,pos)
IF CMP(myChar,car) == 1
loop =0
ELSE
pos = pos-1
END
IF pos<1
loop=0
END
END
RETURN pos
END
//{{{ FindString(string,search,start)
// FindString
// Function: find a substring into a string
// Call: FindString(string,search,start)
// Arguments:
// search = substring to look for
// Return: start position of substring
// 0 if substring does not exist
// into string
// -1 if invalid start position
// than string length) or if
// substring is empty
FUNCTION FindString(string,search,start)
LOCAL found j pos lastpos lstr lsrch
found = 0
lastpos = start
lstr = LEN(string)
lsrch = LEN(search)
IF (CMP(search,"") == 1)
RETURN -1
END
WHILE ((pos = Find(string,CHAR(search,1),lastpos)) > 0)
j = 1
found = 1
IF (j == lsrch)
RETURN pos
END
WHILE ((j < lsrch) && (found == 1))
IF ((pos+j) > lstr)
RETURN 0
ELSE
IF (CMP(CHAR(search,j+1),CHAR(string,pos+j)) == 0)
lastpos = pos+j
found = 0
END
END
j = j+1
END
IF (found == 1)
RETURN pos
END
END
RETURN pos
END
//{{{ LeftString(string,number)
// LeftString
// Function: extract a substring beginning
// at the start of a string
// Call: LeftString(string,number)
// Arguments:
// number = number of character to
// extract from string
// Return: result substring
// or 0 if number is negative
// or null.
FUNCTION LeftString(string,number)
LOCAL size
size = LEN(string)
IF (number > 0)
IF (number > size)
number = size
END
RETURN CUT(string,1,number)
END
RETURN 0
END
//{{{ RightString(string,number)
// RightString
// Function: extract a substring ending
// at the end of a string
// Call: RightString(string,number)
// Arguments:
// or null.
FUNCTION RightString(string,number)
LOCAL size
size = LEN(string)
IF (number > 0)
IF (number > size)
number = size
END
RETURN CUT(string,size-number+1,size)
END
RETURN 0
END
//{{{ MidString(string,first,size)
// MidString
// Function: extract a substring from a
// string
// Call: MidString(string,first,size)
// Arguments:
// first = start position in string
// cha�ne
// size = number of characters
// or 0 if number or first are
// negatives or null.
FUNCTION MidString(string,first,size)
LOCAL ln
ln = LEN(string)
IF ((first > 0) && (size > 0))
IF ((first+size-1) > ln)
size = ln-first+1
END
RETURN CUT(string,first,first+size-1)
END
RETURN 0
END
//{{{ InsertAtPos(string,insert,pos)
// InsertAtPos
// Function: insert a string in another
// string at a specified position
// Call: InsertAtPos(string,insert,pos)
// Arguments:
// insert = string to insert
// pos = start position for insertion
// Return: result string after insertion
// or 0 if start position is
// invalid (negative, null or
// higher than string length)
FUNCTION InsertAtPos(string,insert,pos)
LOCAL workstr str1 size
size = LEN(string)
IF ((pos < 0) || (pos > size))
RETURN 0
END
IF (pos == 0)
RETURN insert""string
END
IF (pos == size)
RETURN string""insert
END
workstr = CUT(string,1,pos)
IF (pos < size)
str1 = CUT(string,pos+1,size)
RETURN workstr""insert""str1
ELSE
END
END
//{{{ ADVANCED
//{{{ InsertAfter(string,insert,search)
// InsertAfter
// Function: insert a string after each
// occurence of a character or
// a set of characters into
// another string
// Call: InsertAfter(string,insert,search)
// Arguments:
// search = character or substring
// to look for
FUNCTION InsertAfter(string,insert,search)
LOCAL pos workstr size
pos = 1
workstr = string
size = LEN(search)
WHILE ((pos = FindString(workstr,search,pos)) > 0)
workstr = InsertStringAtPos(workstr,insert,pos+size-1)
pos = pos+size+LEN(insert)
END
RETURN workstr
END
//{{{ InsertBefore(string,insert,search)
// InsertBefore
// Function: insert a string before each
// another string
// Call: InsertBefore(string,insert,search)
// Arguments:
// to look for
FUNCTION InsertBefore(string,insert,search)
LOCAL pos workstr
pos = 1
workstr = string
workstr = InsertStringAtPos(workstr,insert,pos-1)
pos = pos+LEN(search)+LEN(insert)
END
RETURN workstr
END
//{{{ Delete(string,search)
// Delete
// Function: delete all occurences of a
// substring into a string
// Call: Delete(string,search)
// Arguments:
// search = substring to delete
// Return: result string after deletion
FUNCTION Delete(string,search)
LOCAL workstr str1 str2 pos size
workstr = string
pos = 1
size = LEN(search)
WHILE ((pos = FindString(workstr,search,1)) > 0)
IF ((pos != 1) && ((pos+size) < LEN(workstr)))
str1 = CUT(workstr,1,pos-1)
str2 = CUT(workstr,pos+size,LEN(workstr))
workstr = str1""str2
ELSE
IF (pos == 1)
IF ((size+1) < LEN(workstr))
workstr = CUT(workstr,size+1,LEN(workstr))
ELSE
workstr = ""
END
ELSE
workstr = CUT(workstr,1,pos-1)
END
END
END
RETURN workstr
END
//{{{ Replace(string,search,repl)
// Replace
// Function: replace each occurence of a
// substring into a string with
// another string
// Call: Replace(string,search,repl)
// Arguments:
// repl = replacement substring
// Return: result string after replacement
FUNCTION Replace(string,search,repl)
LOCAL pos workstr str1 str2 size
pos = 1
workstr = string
size = LEN(search)
IF (pos == 1)
str1 = CUT(workstr,size+1,LEN(workstr))
workstr = repl""str1
pos = 0
ELSE
IF ((pos+size) < LEN(workstr))
workstr = str1""repl""str2
ELSE
END
END
pos = pos+LEN(repl)
END
RETURN workstr
END
//{{{ NewParse(string,divider)
// NewParse
// Function: cut a string into several parts and
// store each part into a variable.
// The string is cut before each
// occurence of a specified character.
// Call: NewParse(string,divider)
// Arguments:
// divider = character used as a separator
// between each part of the string
// Return: number of variables created.
// This function create global variables
// named var(1), var(2)...var(N), where
// N is the value returned by the function.
// Note: if the string contained two or more
// successive separators, no variable is
// created for these parts of the string.
// For example, if you call the NewParse
// function for "First;;Second" with
// divider=";", only two variables are
// created (var(1)="First" and
// var(2)="Second").
FUNCTION NewParse(string,divider)
LOCAL pos i workstr size
i = 0
pos = 1
workstr = string
IF ((CMP(workstr,"") == 0) && (CMP(divider,"") == 0) && (CMP(workstr,divider) == 0))
WHILE ((pos = Find(workstr,divider,1)) > 0)
IF ((pos != 1) && (pos != LEN(workstr)))
i = i+1
var(i) = CUT(workstr,1,pos-1)
workstr = CUT(workstr,pos+1,LEN(workstr))
ELSE
IF (pos == 1)
IF (pos != LEN(workstr))
workstr = CUT(workstr,2,LEN(workstr))
ELSE
workstr = ""
END
ELSE
workstr = CUT(workstr,pos,LEN(workstr))
END
END
END
if (CMP(workstr,0) == 0)
i = i+1
var(i) = workstr
END
END
RETURN i
END
//{{{ FileRequester(title,path,file,pattern)
// FileRequester
// Function: open a file requester
// Call: FileRequester(title,path,file,pattern)
// Arguments:
// title = requester title
// path = default directory
// file = default filename
// pattern = default pattern
// Return: 0 if user clicks on Cancel
// 1 if user chooses a file. This
// function creates three global
// variables: pathname (path
// to choosen file), filename
// (name of choosen file without
// extension) and extension
// (extension of choosen file)
FUNCTION FileRequester(title,path,file,pattern)
LOCAL fullname point slash size titre
pathname = ""
filename = ""
extension = ""
IF (CMP(pattern,0) == 1)
titre = "|"
ELSE
titre = "|"pattern
END
IF (CMP(file,0) == 1)
titre = "|"titre
ELSE
titre = "|"file""titre
END
IF (CMP(path,0) == 1)
titre = "|"titre
ELSE
titre = "|"path""titre
END
IF (CMP(title,0) == 1)
titre = "Choose a file"titre
ELSE
titre = title""titre
END
tv_ReqFile titre
fullname = Result
size = LEN(fullname)
IF (CMP(fullname,"Cancel") == 1)
RETURN 0
ELSE
IF ((point = LastPos(fullname,".")) != 0)
extension = CUT(fullname,point+1,size)
size = point-1
fullname = CUT(fullname,1,size)
END
IF ((slash = LastPos(fullname,"\")) != 0)
filename = CUT(fullname,slash+1,size)
size = slash-1
pathname = CUT(fullname,1,size)
END
RETURN 1
END
END
//{{{ MADS JUUL PROCEDURES
//{{{{TVP
//{{{ tvp_canWrite()
//Check if the TVpaint can read and write the file system else you have to restart TVP
//RETURNS : Boolean
//DEPENDS : project_getPath()
FUNCTION tvp_canWrite()
LOCAL projectpath rest project canWrite
projectpath = project_getPath()
tv_writetextfile "Exists" projectpath
IF CMP(result,"Forbidden")==1
canWrite = 0
ELSE
canWrite = 1
END
result = canWrite
RETURN result
END
//{{{ tvp_getSlash()
//Returns the path seperater of the OS
//RETURN : "/" or "\"
FUNCTION tvp_getSlash()
LOCAL mySlash
tv_version "ComputerOS"
IF CMP(result,"WIN32")==1 || CMP(result,"WIN64")==1
mySlash = "\"
ELSE
mySlash = "/"
END
result = mySlash
RETURN result
END
//{{{{PROJECT
//{{{ project_getPath()
//Returns complete path of current project
FUNCTION project_getPath()
LOCAL rest
tv_ProjectInfo 0
PARSE result result rest
RETURN result
END
//{{{ project_isSaved()
//Returns a Boolean to tell if current Project is saved or not
//DEPEND on project_getPath()
FUNCTION project_isSaved()
LOCAL projectpath exists slash myResult
exists = projectpath
slash = tvp_getSlash()
IF CMP(exists,projectpath)!=1||CMP(exists,slash )
myResult = 0
ELSE
myResult = 1
END
result = myResult
RETURN result
END
//{{{ project_getParent()
FUNCTION project_getParent()
project_getPath()
file_getParent(result)
RETURN result
END
//{{{ project_getName()
FUNCTION project_getName()
project_getPath()
file_getName(result)
RETURN result
END
//{{{ project_getBaseName()
FUNCTION project_getBaseName()
LOCAL projectName strlen last projectbase
projectName = project_getName()
IF CMP(projectName,"-1")==1
result = -1
ELSE
strlen = LEN(projectname)
last = LastPos(projectname,".")
IF CMP(last,"0")==1
projectbase = projectname
ELSE
projectbase = LeftString(projectname,last-1)
END
result = projectbase
END
RETURN result
END
//{{{ project_getBound()
FUNCTION project_getBound()
LOCAL x2 y2
tv_getWidth
x2= result
x2=x2-1
tv_getHeight
y2 = result
y2=y2-1
result = "0 0 "x2" "y2
RETURN result
END
//{{{ project_getAspect()
FUNCTION project_getAspect()
LOCAL height width aspect
myResult = -1
tv_GetHeight
height = result
tv_GetWidth
width = result
aspect = width/height
myResult = aspect
END
//{{{ project_incrementalSave(divider,part,ask,minimumDigitLength)
//Saves an Incremental file of current TVPP project in the same folder as the currentProject.
//Find the Part of the current file name with the "divider" and the "part" variabled passed to the function
//lets say we have a file called thefox_Q002_S002_v02.tvpp
//And we want to increment the "v02" part. We would calle the function like this
//project_incrementalSave("_",4,1)
FUNCTION project_incrementalSave(divider,part,ask,minimumDigitLength)
LOCAL name slash dir newName myReturn
//CHANGELOG
//2014-11-11 project name can start with a number like "0001_v01.tvpp" without the leading zeros disappear when saving
project_isSaved()
IF CMP(result,"1")1==1
name = project_getName()
name="/"name
dir = project_getParent()
string_incrementalPart(name,divider,part,minimumDigitLength)
newName = dir""result
IF CMP(ask,"1")==1
tv_Request "Increment and save : "newName" |Save|CANCEL"
IF result
tv_SaveProject newName
END
ELSE
END
myReturn = newName
ELSE
myReturn = 0
END
result = myReturn
RETURN result
END
//{{{{STRING
//{{{ string_addZeros(prefix,string,length)
FUNCTION string_addZeros(prefix,string,length)
LOCAL stringPrefix digit stringPostfix cur i
// CHANGELOG
//2014-11-11 Second parameter can be a string instead of an integer with letters before and after string
stringPrefix = string_getPrefix(string)
digit = string_getDigit(string)
PARSE digit digit rest
stringPostfix = string_getPostfix(string)
prefix=prefix""stringPrefix
length=length*1
digit=digit*1
cur = LEN(digit)
length=length-1
FOR i=cur TO length
prefix=prefix"0"
END
result = prefix""digit""stringPostfix
RETURN result
END
//{{{ char_isDigit(char)
FUNCTION char_isDigit(char)
LOCAL myResult
myResult = 0
IF CMP('"0"',char)==1
myResult = 1
END
IF CMP('"1"',char)==1
myResult = 1
END
IF CMP('"2"',char)==1
myResult = 1
END
IF CMP('"3"',char)==1
myResult = 1
END
IF CMP('"4"',char)==1
myResult = 1
END
IF CMP('"5"',char)==1
myResult = 1
END
IF CMP('"6"',char)==1
myResult = 1
END
IF CMP('"7"',char)==1
myResult = 1
END
IF CMP('"8"',char)==1
myResult = 1
END
IF CMP('"9"',char)==1
myResult = 1
END
IF CMP('" "',char)==1
myResult = 0
END
result = myResult
RETURN result
END
//{{{ string_getPrefix(string)
FUNCTION string_getPrefix(string)
LOCAL myLen pos prefix all loop cur test
myLen = LEN(string)
pos = 1
myResult=""
loop=1
WHILE pos<=myLen && loop ==1
cur = CHAR(string,pos)
test = '"'cur'"'
char_isDigit(test)
IF result==1
loop=0
ELSE
myResult=myResult""cur
END
pos=pos+1
END
RETURN myResult
END
//{{{ string_getDigit(string)
FUNCTION string_getDigit(string)
LOCAL myLen pos number loop cur test length
myLen = LEN(string)
pos = 1
number="0"
loop=1
length=0
test = '"'cur'"'
char_isDigit(test)
IF result==1
number=number""cur
length=length+1
ELSE
IF length>0
loop=0
END
END
pos=pos+1
END
result = number" "length
RETURN result
END
//{{{ string_getPostfix(string)
FUNCTION string_getPostfix(string)
LOCAL myLen pos part cur test
myLen = LEN(string)
pos = 1
myResult=""
part=0
WHILE pos<=myLen
test = '"'cur'"'
char_isDigit(test)
IF result==1
IF part==0
part=1
END
ELSE
IF part==1
part=2
END
END
IF part==2
END
pos=pos+1
END
RETURN myResult
END
//{{{ string_increment(divider,string,minimumDigitLength)
FUNCTION string_increment(divider,string,minimumDigitLength)
LOCAL prefix digit length postfix
prefix = string_getPrefix(string)
prefix = divider""prefix
PARSE result digit length
digit=digit*1
digit=digit+1
IF length<minimumDigitLength
length=minimumDigitLength
END
postfix = string_getPostfix(string)
string_addZeros(prefix,digit,length)
result = result""postfix
RETURN result
END
//{{{ string_incrementalPart(string,divider,part,minimumDigitLength)
FUNCTION string_incrementalPart(string,divider,part,minimumDigitLength)
LOCAL length myPart increment all i
length = newPARSE(string,divider)
myPart = var(part)
string_increment(divider,myPart,minimumDigitLength)
increment = result
all=""
FOR i=1 TO length
iF i==part
all=all""increment
ELSE
myPart=var(i)
IF i==1
all=all""myPart
ELSE
all=all""divider""myPart
END
END
END
result=all
RETURN result
END
//{{{{FILES
//{{{ file_getExt(path)
FUNCTION file_getExt(path)
newParse(path,".")
result = var(2)
RETURN result
END
//{{{ file_getParent(path)
FUNCTION file_getParent(path)
LOCAL strlen last
path = Replace(path,'\','/')
strlen = LEN(path)
last = LastPos(path,"/")
path = LeftString(path,last-1)
IF CMP(last,strlen)==1
strlen = LEN(path)
END
result = path
RETURN result
END
//{{{ file_exists(path)
FUNCTION file_exists(path)
LOCAL exists
IF CMP(path,"0")==1
exists = 0
ELSE
tv_WriteTextFile "Exists" path
exists=result
if CMP(exists,path)==1
exists = 1
ELSE
exists = 0
END
END
result = exists
RETURN result
END
//{{{ file_getName(path)
FUNCTION file_getName(path)
LOCAL fileName strlen last
IF CMP(path,"/")==1 || CMP(path,"\")==1
fileName = -1
ELSE
strlen = LEN(path)
last = LastPos(path,'/')
fileName = RightString(path,strlen-last)
END
result = fileName
RETURN result
END
//{{{ file_readTextFile(textFilePath)
FUNCTION file_readTextFile(textFilePath)
LOCAL myReturn fileExists i line text
myReturn = 0
tv_WriteTextFile "Exists" textFilePath
fileExists = result
IF CMP(fileExists,textFilePath)==1
loop = 1
i=0
WHILE loop==1
tv_readtextfile i textFilePath
PARSE result line text
IF CMP( line, "EOF" ) == 1
loop=0
ELSE
length = LEN(text)
length=length-2
text = CUT(text,1,length)
IF i==0
myReturn=text
ELSE
myReturn=myReturn"\n"text
END
END
i=i+1
END
END
result= myReturn
RETURN result
END
I am still on TVP 10, but according to Joost there is no error at all.
Oh nice, that makes sense. I'll include those and see if that fixes this script. Thanks!
The other button that Joost uses a lot is based on Svengali's FigureFill script (with some added pre-/post-actions) that no longer works: viewtopic.php?f=11&t=5690&hilit=figure+fill&start=45
- LukasKrepel.nl
Switching to TVPaint 11 should make the FigureFill script unnecessary . The function is built-in to TVPaint 11. Of course, the added pre-/post- actions may be what he still wants to use ?Lukas wrote: ↑01 Apr 2021, 09:19 The other button that Joost uses a lot is based on Svengali's FigureFill script (with some added pre-/post-actions) that no longer works: viewtopic.php?f=11&t=5690&hilit=figure+fill&start=45
Svengali's own advice regarding his FigureFill script:
Svengali wrote: ↑12 Oct 2015, 01:48
Changes in TVPaint 11 have made FigureFill obsolete.
Instead, choose Filled-Stroke and make sure to check the box labeled FILL INSIDE. Then simply circle the shapes you want to have filled with the APen color. It's much easier to use and much more sophisticated a solution for individual shape filling.
Thanks D.T. Nethery
The pre-/post- behaviour was simply putting a color layer below the current line-art layer with the same length etc and fill the line art on that new layer on all frames with 1 color with the 'above' function while excluding foreground items. If there's a way to do that with the new system, that's fine too!
Joost tried the new way, but mentioned it was more work and had worse results. Hopefully the results can simply be improved by adjusting the tool settings. Maybe he can share a screenshot of the issue.
- LukasKrepel.nl
This is one of the examples from the new tool. It sometimes draws outside of the line art. And some spaces are kept empty when I would like to have them filled.
With the previous tool from Lukas this never happened....
I will try to post more pictures about it.
TVP Pro 11.7.1
TVP Pro 11.7.1
This is an example from a gap within a drawing...(maybe it's not easy to see but its a pencil)
- Screenshot 2021-04-02 at 13.25.42.png (33.47 KiB) Viewed 69989 times
TVP Pro 11.7.1
TVP Pro 11.7.1
And some more. All in one simple drawing.
I tried to tweak the numbers from the tool a bit, but the result wasn't much better...
- Screenshot 2021-04-02 at 13.32.00.png (69.93 KiB) Viewed 69989 times
TVP Pro 11.7.1
TVP Pro 11.7.1
Hey Joost,
Those artifacts in your posts look like gap closer roundings, these usually appear in sharp corners.
Because you always have neatly closed shapes the Gap Closer value can be left at zero, which should minimize them.
Then the color Range can also be set pretty high because your lines are always nicely black.
And you could set an Expand on the fill, since you have quite thick lines you could safely set the expand to a value between 2 and 4.
Expand will result in the color filling
halfway under your lines, eliminating those little holes.
I also wonder if instead of Fill Inside (filled stroke) adding fill colors using CTG method may suit your purposes better ? (in TVPaint 10 , you might know CTG as "LazyBrush") . CTG fills are fast and precise. (*UPDATE: see my post below responding to Svengali's new version of his FigFill script. Svengali's script is faster for filling a character with a single color. The reason I mentioned CTG for doing the color fills was because I saw that a few of your sample frames had more than one color. )
https://www.tvpaint.com/doc/tvp11/index ... l-concepts
https://www.youtube.com/watch?v=FDjQNvbgzmw
The downside of using CTG layers is if you need to share the file with people who do not have TVPaint 11 PRO (for example TVPaint 11 Standard or TVPaint 10 Pro/Standard) then CTG layers will be invisible to them if you share your .tvpp file with them. The workaround is to duplicate the project , convert all CTG layers to regular ANIM layers, then you can share it with someone using TVPaint 11 Standard or TVPaint 10 Pro or Standard and they will be able to see the color fill layers when they open the file.
This needs to be tested in 11.5, if someone has a few minutes. It seems to work for me in 11.0.10. 64bit.
Go to the line layer and press the New Fig Fill Button. The script is embedded.
NEW FIG FILL BUTTON
This New Fig Fill button is an update of the original FIG FILL button from years ago, but it specifically incorporates the adaption that Lukas posted back then. The updated features:
1. The color fill layer is automatically generated under the existing outline layer.
2. The color filled frames on the color layer are auto-generated beneath the Instances (head) frames of the line layer.
3. The entire color layer and frame-filling process (new fill layer and automatic instances with color) is immediately undo-able by pressing a single Ctrl-Z.
I have to say I was surprised anyone was still using this script from 2012, but I downloaded the Lukas version from the old thread to see what had been added, then updated the script to incorporate those tweaks in the new script I'm posting here.
sven
NEW FIG FILL BUTTON
sven
- New Fig Fill 2021.tvpx
- (95.5 KiB) Downloaded 2131 times
The script works great in 11.5.1 ! The script works much faster for filling a character with a single color that using CTG as I had suggested in a previous post.
