TheQuestionMark wrote: ↑14 Mar 2021, 01:53
TVPaint 11.5.1 Update Virtually Erases all the Brushes in the Bin.
That did not happen when I updated to 11.5.1 , but it probably just means you updated and then started up TVPaint with the default (clean) configuration , so your Custom panels are not there in the default configuration. You should be able to change the configuration in the Start Up Panel to use your previous config file , which should restore your custom brush panels.
I did load it up to default folder? The layout is the same. But My all my custom brush folders aren't loading up.
Okay could you try dragging and dropping one of them into your TVPaint window and see what happens?
Also, are some non-default panels appearing your Custom Panel menu list inside TVP?
