Help me understand selecting multiple layers
Joost
Post by Joost »
Hi there,
In TVP 11.5.1 I don't really understand how to select multiple layers using the SHIFT key on my keyboard.
In tvpaint 10 I used to click in the layer thumbnail then hold shift, then select a different layer: All layers in-between the two selected layers where selected.
But in TVP 11.5.1 it's not clear when all layers in-between are selected and when just the two layers that I clicked on are selected. It feels random to me.
Sometimes TVPaint selects only the two selected layers and sometimes all layers in-between. Even when I think I do exactly the same, the behaviour seems to be always different.
Is there anybody who can explain what I'm missing?
TVP Pro 11.7.1
Re: Help me understand selecting multiple layers
Selecting multiple layers holding down the Shift key works the same in TVPaint 11. Most of the time I have no problem with selecting multiple layers in the usual way you described: "click in the layer thumbnail then hold shift, then select a different layer: All layers in-between the two selected layers where selected." but I do notice that occasionally there will be a slight delay before all the layers show as selected with the highlighting... sometimes the layers don't show as selected until I move the cursor up or down slightly , then the highlighting shows they are selected. This behavior is difficult to describe or predict. In the attached screen capture , you can see me selecting multiple layers by holding down Shift ... you can see it happens a few times there is a slight lag before all the layers have the highlighting which shows they are selected . I have no idea why it does this from time to time. It doesn't always happen. Seems random. It hasn't bothered me enough to report it as a bug , but I suppose it is a bug (?). As I say, usually when it happens if I just move my cursor up or down a bit the highlighting kicks in , so I can see all the layers selected.
https://www.youtube.com/watch?v=0mnZs569Qb0
Joost
Post by Joost »
Oh, now I see. Yes it's a delay indeed!
Maybe I was too impatient and just tried selecting them again when I should have waited.
Thanks for pointing that out!
The delay however is still a bit strange...
TVP Pro 11.7.1
Joost
Post by Joost »
Well, after some more experience. Selecting layers is still a bit more difficult than it used to be.
It's not just a delay. Sometimes TVPaint simply doesn't select the layers I want. I have to select the layers multiple times to get the right selection.
And another thing that is really strange behaviour to me:
When I did manage to select the layers, and I zoom out, the selected layers are automatically deselected. :shock: This must be a bug, right?
Hopefully the TVPaint team can take a look at this one.
Thanks in advance!
TVP Pro 11.7.1
Soom
Post by Soom »
I actually remember this issue was a problem also in some previous versions
https://vimeo.com/danas
Joost wrote: 12 Apr 2021, 07:46And another thing that is really strange behaviour to me:
Thanks in advance!
I've tried to reproduce that one, but it doesn't seem I have the bug you're describing.
See the attached video of me trying to do it:
selecting-zooming-out.zip
(266.98 KiB) Downloaded 665 times
--TVPaint 11.5.1 (March 15th build)
Soom
Post by Soom »
I have it (on Windows, will check on Mac later)
Here is the recording...
tvp_layer_selection.mov
(1.91 MiB) Downloaded 638 times
(there is no sound, so just to clarify - each time I press Shift and select some other layer. Sometimes the layers in between get selected, sometimes not. It's random. Sometimes if i move or zoom the timeline (not the canvas, like you do in your video), they suddenly get selected (I think this is also what Joost meant too)
Joost
Post by Joost »
Thierry wrote: 16 Apr 2021, 15:54
Thanks in advance!
See the attached video of me trying to do it:selecting-zooming-out.zip
Thanks for your reply Thierry.
I didn't make myself clear enough. I forgot to type: Zoom out "on the timeline" (alt-right mouse button)
So if I have multiple layers selected, and then I want to zoom out on the timeline, the selected layers will be deselected...
TVP Pro 11.7.1
Joost
Post by Joost »
[/quote]
[/quote]
Apparently, this deselecting "bug" is not showing up in every project I open. But I don't know when and why it's not appearing sometimes.
It definitely shows up when opening a new project.
TVP Pro 11.7.1
Joost wrote: 19 Apr 2021, 08:53 Apparently, this deselecting "bug" is not showing up in every project I open. But I don't know when and why it's not appearing sometimes.
It is the same for me: it sometimes happens , but not all the time. I tried to capture the behavior (layers deselected when expanding or compacting the timeline) with a screen capture video , but when I had the screen capture running I could not reproduce the behavior. It doesn't happen so much that it is bothersome (to me) , so I've learned to live with it. I imagine it could be quite annoying to many people , so I hope they can find out what causes the problem and are able to fix it.
