Copy Paste Colormarks
schwarzgrau
Post by schwarzgrau »
I created this script for myself, but I thought maybe others could find it use for it aswell
You need to select a few frames (or all) of the source layer and use the copy button, which will save the selected colormarks to the ini file (so you could even paste it another time).
And than you can select the target layer and use the paste button, to paste them at the current time.
The Panel comes with bright and dark icons, to make it useable with different themes.
Hope somebody finds use for it aswell.
CopyPasteColormarks_v01_0.tvpx
(303 KiB) Downloaded 1465 times
Re: Copy Paste Colormarks
Yes! this is an excellent one thanks Marc!
schwarzgrau
Thank you Peter! I guess it has it flaws, since I wrote it pretty quickly, but for now it kinda worked.
By the way in my case I needed to reimport my layers from After Effects. But usually you would loose all marks and so I was able to copy over my color marks from an older state.
